(Q) can you send us Acetylene gas cutting table parameters
Attachment 286578
Notice the cutting data condition:
1. The purity of oxygen should not be less than 99.5%.
2. Carbon of steel plate should be ≤0.45%.
3. Cutting method should be vertical cutting.
4. Oxygen pressure given is preheat oxygen before cutting.
(Q) THC operation guide
Attachment 286572-THC Operation guide
ST-THCEX03
Attachment 286574
Height: 0-30(60-160)
It is the expected value of the torch height, set by users. Larger the value, working height will be set higher.
60~160 is the value you will see in the display
Cutting Height, It is the relative height the THC maintains for the ARC voltage.
Sensitivity: 0-10
To adjust the sensitivity of the THC. To increase the sensitivity of THC lowers this value. Height ± Sensitivity value the THC will not be adjusted its height.
IHS Height: 0-100(0-12) mm
Before pierce, the torch will go down and touch the plate, then the torch will be lift to a certain height, this height is the IHS height. 0~12 mm is the height the can be adjusted
The initial piercing height.
Attachment 286580
1.This display on the first digit shows, the THC is in ARC voltage mode
2.This display on the first digit shows, the THC is moving UP
3.This display on the first digit shows, the THC is moving DOWN
4.This display on the first digit shows, the THC reached HIGH LIMIT
5.This display on the first digit shows, the THC reached LOW LIMIT
More information about SteelTailor FAQs, Pls visit:
Forum - Powered by Discuz!
Hope this is helpful to you .
Any other question ,pls email at service@steeltailor.com.
You can also find us easily on facebook:SteelTailor Twitter:SteelTailor,
