586,047 active members*
3,800 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > "Parker Daedal" mirror - replacement advice?
    Feb 2010
    58
    I've got a couple of these on a table with a 100W C02 tube, one has deteriorated significantly ..
    Other than it saying Parker Automation Daedal Division on it I don't see any kind of identifier.
    This is used in the beam directional path.
    Could I get a 25mm mirror such as the one below and mount it in place of the peeled one? .. or even directly on top of it?
    25 mm Molybdenum (MO) Reflection Mirror
    Attachment 287184
    Feb 2010
    58
    Re: "Parker Daedal" mirror - replacement advice?
    After looking at this mirror in different lighting, it appears that this peeling area is some kind of coating that maybe should have been taken off?
    The perimeter border area has always been the different color, giving the impression that a mirror was embedded in the surface. However looking closer at the areas where it peeled, it's revealing a constant surface below that is consistent with the edges.
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. Replies: 2
    Last Post: 07-03-2010, 12:27 AM
  3. 55"x70", leadscrew advise needed
    By Gads in forum DIY CNC Router Table Machines
    Last Post: 04-29-2010, 08:32 PM
  4. Programmable mirror image "15 mf"
    By cncwhiz in forum Fanuc
    Last Post: 01-07-2008, 10:42 PM
  5. Parker Daedal servo CNC table Project
    By GEORGETOUBALIS in forum DIY CNC Router Table Machines
    Last Post: 12-18-2007, 05:19 PM
