588,191 active members*
4,274 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Car hoist 3phase settings on huanyang vfd
    Aug 2015
    Hi all. I have a question for you and hope you can help. I have the 2.2kw vfd Huanyang i have used it on my 3phase planer with no problem. But me and my mate just installed a car hoist at his house" we love land rovers but need constant care" anyway the motor is 3 phase 1.7kw, 2850 rpm 50hz delta think amps is 8. i have rigged it to the vfd. I had no car on it and pressed run and the lift went up all the way. But when i put a car on it the motor goes on and lift the back side of the lift 1 inch and then the motor stops turning i can hear its on but it seems like there is not enough power. I believe that it could be something in the settings but i have to be honest im struggling with understanding all the settings. can you help. thanks
    Re: Car hoist 3phase settings on huanyang vfd
    Quote Originally Posted by pietskiet View Post
    Grave dig.
    Did you haveany luck finding a solution mate as I'm having the very same problem...and the hoist runs EXTREMELY slow
  1. Huanyang Chinese VFD settings and manual here!
    By diyengineer in forum Spindles / VFD
    Last Post: 03-14-2024, 03:15 AM
  2. Huanyang Spindle noise, and Jog settings.
    By dkemppai in forum Spindles / VFD
    Last Post: 12-03-2013, 02:24 AM
  3. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  4. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
