586,666 active members*
4,931 visitors online*
Results 1 to 9 of 9
    May 2005
    Question Any Experience with Ah - ha Contollers?
    I am looking for any advice that you all may have with the Ah - ha PC based controller. Good, Bad, indifferent? Is it supported? Manuals easy to find?
    Etc.
    Thank you,
    Ed
    Dec 2003
    259
    I run two of them and have been doing so for a while, probably about 7 or 8 years.
    I only run the controller then take the output from the Ahha board via a breakout board to Gecko 210 drivers.
    We don't run the Ahha driver box as it's not passed for electrical safety here in the UK.
    Never had a Ahha based problem, had many problems, machine based, computer based and plenty of operator based ones [ me ] but never a Ahha problem.
    Good manual comes with the board and software and we get very good UK support from Ian Eagland at Eagland Machine Tools
    http://www.eagland.co.uk
    I have though about upgrading these two big machines to Mach3 but to be honest they are bombproof, fool proof and earn me money on a daily basis and for what they do mach3 would probably not give me anything extra.
    John s.
    May 2005
    Hello John,
    Thank you for the quick reply. I am planning to go look at a machine with the Ah - ha controller, and being new to CNC, did not have experence with them.
    Best wishes,
    Ed
    May 2005
    14
    I have had my ah-ha about four years and have had no problems with it.
    It has only ran about 15-20 hours month,which is'nt much but it gets it done.
    There is a user group at yahoo with lots of good infromation and very helpful people. I bought mine from Al Goshey, at E-Mtech here in the USA, and had no problem getting help when I need it.
    Good Luck.
    Stephen D.
    http://www.e-mtech.com/
    http://groups.yahoo.com/group/ahha_cnc/
    332
    Needed a new driver board. 6 amp board died with no clue to reason. No smoke, no red lights. Turned on the box one day and an axis was dead. No reply to email sent to website admin address. Found the name of the board builder on a Yahoo group website. Emailed him and was told that he has them but they can only be bought from dealer. Dealer finally emailed, $350 for a board.
    Bought a 212 Gecko for $168 vs. 6 amp ahha board for $350.
    Wired into the RC500 box and runs fine.
    4 wire stepper motor wired a,a-/b,b-, power connections via existing ribbon lead with modular plug removed, used step, direction and enable to connect to gecko step, direction and common. Kept the line polarities as before. Changed the steps/inch to accomodate the 1/5 microstep setting on the gecko.
    Had to add a heatsink to attach the new driver inside the black box.
    Gekco arrived in two days. Someone answers the phone. Parts in stock. Knowledgable helpful owner and great service.
    Ahha is a fair piece of software but was never as good as newer less expensive options.
    Jul 2004
    9
    wire connection needed
    Hi!
    I having same trouble like you have in teh past and replace the board die for a Gecko 201 but something rong happen! At first power up, the geckocan move the Z axes a little slow and making noise, so I turned dawn and tried start up again but the computer make some noise (beep, beep, beep) and not power up and the monitor screen was in blank.
    Could youd sen me the wire connection that you made, so I can check the connetion I do. me email is: [email protected]
    I will apreciate very much!!
    Quote Originally Posted by keithorr View Post
    Mar 2009
    19
    Quote Originally Posted by John S. View Post
    Eagland Machine Tools for Cnc Retrofit and Cad-Cam
    John s.
    I would like to fit something like your ahha system on my own large machining centers. Could you tell me about your machines. which machines they are, how big they are?
    Jul 2016
    11
    Re: Any Experience with Ah - ha Contollers?
    Hi , Ive recently bought a Bridgeport seiries 1 with what i think is a ahha driver and a rs-232 27pin input for a computer. I would like to connect the machine to a computer and preferable use mach not DOS any help would be greatly possible.
    Mar 2012
    1570
    Does anyone know where I can get a copy of the ahha software?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  1. YCM experience?
    By DDLES in forum Uncategorised MetalWorking Machines
    Last Post: 05-17-2010, 08:03 PM
  2. CNC with DTP experience
    By lashbeck in forum Employment Opportunity
    Last Post: 03-26-2010, 08:52 PM
  3. Need some help from those who have Experience.
    By Scra99tch in forum Vertical Mill, Lathe Project Log
    Last Post: 06-20-2007, 04:55 PM
  4. Servo Contollers, Which one?
    By bcromwell in forum Servo Motors / Drives
    Last Post: 04-24-2007, 04:25 AM
  5. My first experience with CNC
    By NeoMiller in forum DIY CNC Router Table Machines
    Last Post: 10-10-2003, 02:08 PM
