586,067 active members*
5,098 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Need help with Toolpaths...
    Mar 2010
    621
    Trying my luck at Aspire and having some problems with tool paths and the model I've designed... its a dished model.
    After creating a roughing tool path it appears to me that the milling starts above the model and I'm not sure where or how to set it to "Z" Zero.
    Can anyone confirm this for me from the images I've attached?
    I'm assuming that the "Red" line indicates Z zero in the model, green lines Z up and Z Down and the blue lines X and Y movement.
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Jun 2008
    562
    Re: Need help with Toolpaths...
    The Red is your safe z travel height I believe. You set the Z zero on the first material setup page, either top or the bottom of the material. Take a look at the tutorial they are much help.
    Mar 2010
    621
    Thanks for the post...
    I ran a test piece last night and it seems to have come out correctly.. I think you are correct, the "Red" line was the Safe Z.
    Adam,
    Feb 2009
    192
    Quote Originally Posted by adam_m View Post
    Adam,
    Correct the 'RED' is your Safe Z at whatever distance you entered for the toolpath. And yes, actuall 'Z0' is from the part face or bottom.
  1. Replies: 23
    Last Post: 10-31-2014, 03:26 PM
  2. 3D Toolpaths
    By coykiesaol in forum Jewelry Design Software
    Last Post: 11-09-2010, 08:21 AM
  3. Can anyone help me with toolpaths for this???
    By cloverfield333 in forum Mastercam
    Last Post: 12-21-2009, 04:21 PM
  4. new 3d toolpaths
    By camtd in forum GibbsCAM
    Last Post: 01-01-2009, 10:06 PM
  5. Need help with toolpaths.
    By vigilante212 in forum Mastercam
    Last Post: 11-14-2007, 10:51 PM
