586,089 active members*
3,933 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Talon 208 w/ Acramatic 850 SX
    Mar 2011
    22
    Hello, we have a problem with our spindle. This has the Siemens spindle drive. When try to stop the spindle, the drive will drop out, letting the spindle coast to a stop. We are running at 1000 rpm. According to the operator, this started after there was a fluctuation in voltage in the plant. thanks.
    Dec 2006
    584
    Re: Cincinnati Talon 208 w/ Acramatic 850 SX
    It sounds like you have a bad braking resistor or circuit. Try to reduce the spindle speed in 250 rpm increments or less to 0 rpm. What error does the spindle drive have on it?? Send a pic of the spindle drive.
    MIKE http://cncmachinservices.com
    Mar 2011
    22
    Thanks for your reply. This is a Siemens spindle drive (SIMODRIVE). We did try your suggestion about stepping down the rpm in increments, but it drops out regardless. e.i. 1000 to 800 rpm drive drops out. We get alrm F42 on the Simodrive, and Alarm # 14068 on the crt. The main problem we have besides the actual fault, is we don't have any manuals for this drive. Thanks.
    May 2014
    16
    sounds like I have the same machine, I do have some manuals let me know what you might need and I can take a look.
    [email protected]
    Nov 2016
    Hello, after press the cycle start button i get an alarm "Cycle start inhibited". Please help me
  1. Replies: 13
    Last Post: 09-28-2015, 05:04 PM
  2. cincinnati talon 208 start up prob
    By Hydratight in forum Cincinnati CNC
    Last Post: 08-28-2014, 04:47 AM
  3. post processer for Acramatic 850sx talon lathe,
    By dj_pigs in forum Tutorials
    Last Post: 02-03-2013, 05:13 AM
  4. Help with a cincinnati talon 208 milacron 850sx
    By player202013 in forum Uncategorised MetalWorking Machines
    Last Post: 12-27-2007, 05:50 AM
  5. Acramatic Contol on Cincinatti Talon Turning Center
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 06-02-2004, 05:19 AM
