603,386 active members*
3,191 visitors online*
    Mar 2015
    17
    Mach3 lowers Z and crashes tool at tool change.
    Hey guys. I'm having an annoying problem during a simple tool change. At the "T2 M6" line, I insert the tool into the spindle and press "cycle start". This causes the Z to slowly extend all the way down and crash the tool into my work. Mach does not seem to move beyond the "T2 M6" line. The spindle never starts or anything. I end up hitting reset but I'm assuming the Z would continue to go until it hits limits. Any ideas? Thanks in advance
    (2D CONTOUR1)
    M5
    M9
    M1
    T2 M6
    S6300 M3
    M9
    G0 X1.8256 Y-1.7295
    Mar 2015
    17
    Re: Mach3 lowers Z and crashes tool at tool change.
    After spending a good while digging around, I stepped through the M6End.m1s macro and found that it was causing the z move. I purchased this machine second hand and I suspect the previous owner edited this file. All set now.
  1. Need Help - Tool change position mach3
    By extsuba in forum Mach Mill
    Last Post: 04-11-2016, 07:47 PM
  2. Mach3 unexpected plunge after tool change
    By CabinDigital in forum Mach Mill
    Last Post: 02-19-2016, 11:11 PM
  3. Replies: 0
    Last Post: 11-24-2010, 09:00 PM
  4. X2 + mach3 - manual tool change??
    By touser in forum Mastercam
    Last Post: 03-02-2008, 07:56 PM
  5. tool change with mach3
    By timmyb199 in forum Vectric
    Last Post: 10-18-2006, 11:29 PM
