603,385 active members*
3,046 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > UK Builders check out a router bargain in B&Q
    Nov 2003
    314
    UK cnc builders must check this out, a 700w router perfect for a diy cnc project, it is on special offer at B&Q £29.98 !!!
    I bought mine before Xmas and thought I got a bargain for £46.99.
    http://www.diy.com/diy/jsp/bq/produc...maxBullets=999
    If you have problems with the link above type in 701w on the search button at www.diy.com - great web site address for a diy store. !!
    It is really their version of a rotazip 700watt variable speed max 30,000 1/8 and 1/4 collet chuck.
    Kit comes with plunge router, circle cutter, flexible drive, freehand clamp/handle (like a rotazip) and a really clever angle grinder/sander attachment.
    It even has a light. !!!
    Fantastic value for money, I have used it loads of times since I bought it and intend to use it for my cnc machine as it is ideal for fitting.
    This is one of B&Q's own brand machines in the pro series, which you can register on line and get 3yr warranty !! How can you beat that.
    Going to buy another one, as I will end up leaving this one in the CNC machine.
    Nov 2003
    314
    Here is a pic inside my box
    Nov 2003
    314
    And the router itself
    May 2003
    79
    I bought one this morning.Quite a lot of goodys for very little money.The router seem quite robust as well.
    Thanks for the tip!!!
    Mark
    http://www.weardalecnccarving.co.uk
  1. Finding The Right Router
    By Crushmonkey in forum Commercial CNC Wood Routers
    Last Post: 06-19-2006, 07:17 AM
  2. long term stability of wood framed router
    By dave925 in forum DIY CNC Router Table Machines
    Last Post: 05-06-2005, 05:33 AM
