I may have aneed soon to have some cutting done, I'm concerned that the material may give off fumes if it is cut with a laser which is my usual method so I suppose some form of CNC cutter would be appropriate. I'd like to get a rough idea of cost and identify someone I might discuss this further with.
The material would be 12" x 12" PVC, pretty thin, probably 7 mil. The cutting wouldn't be especially complex, probably about 36" in patterns that would be specified electronically in an AutoCAD or Adobe Illustrator file. I'd probably want to do a coupld of sheets to start but then if things work out possibly several more later.
I would supply the plastic material and the template in electronic form.
If you're able to provide a rough estimate per sheet based on low (1-2) quantities and the larger quantities (10+) please post or send me a message.
Despite my username I am based in the US by the way.
Thanks, Chris.
