603,958 active members*
2,572 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Jun 2014
    27
    Exclamation Mach3 jump lines of code
    I'm building a 3 axis hobby cnc router to test the machine I made a model of batman logo to my son in SolidWorks and use SolidCAM to generate the G-Code. In the first test run I was using Styrofoam, now I'm glad to choose that material. For some reason mach3 jump part of the code and the tool just open it's way in the part. The error shows up between the lines 16627 and 16634 that part was ignored.
    Regards,
    Sidney
    35494
    Re: Mach3 jump lines of code
    It's much more likely that your machine lost steps and lost position. Mach3 does not skip lines of g-code.
    Jun 2014
    27
    In the beggining that was my thought too. But I replace everything on the machine and the problems still exists. And the strange part is that everything its normal until that line. That its completely ignored and tool goes on to the next point and in the next -z move the tool goes down and I lost the part.
    I'll try again.But this time I'll make a video to show how things happen.
    Regards,
    Sidney
    35494
    Try reducing your acceleration by 50% first.
    Jun 2014
    27
    Here is the link to the video:
    https://youtu.be/a5QSn9uAwL0
    I left the video with almost 20 minutes so you can see that everything was alright until the lines 16627@16634. If you wanna see the trouble you can go directly to 19:00 minutes of the video.
    Apr 2013
    1916
    I think it would be better and easier to help if you would post the part of the code which is skipped. Perhaps there is something wrong with the line or several lines. I think that might be difficult to see and also the video is 19 minutes long, so it demands a great deal of patience from anyone willing to help. Personally, I think it is too long for my patience. Other than that, you also want us to open the video and read the details elsewhere. Why? Why not just paste the relevant text here?
    Jun 2014
    27
    Quote Originally Posted by A_Camera View Post
    In part I agreed with you. The video is long but you can click anytime to any position on the video.
    Here is the part that I agreed with you, where in the video the problem happens.
    And Here is the code generated by SolidCAM:
    This block was ignored:
    "G3 X24.243 Y-61.268 Z-8.454 R1.371 F841
    X24.377 Y-61.261 Z-7.404 R1.371
    X24.51 Y-61.242 Z-5.699 R1.371
    X24.641 Y-61.209 Z-3.404 R1.371
    X24.768 Y-61.163 Z-1.11 R1.371
    X24.889 Y-61.106 Z0.596 R1.371
    X25.005 Y-61.037 Z1.645 R1.371
    X25.112 Y-60.957 Z2. R1.371"
    And this block move the tool to the next point:
    "G1 X25.359 Y-60.81 F2000
    X25.373 Y-60.783
    X25.354 Y-60.759
    X-17.56 Y-34.877
    X-17.578 Y-34.853
    X-17.523 Y-34.804
    X-17.3 Y-34.704
    Z-7.732"
    Thanks for the comments I'll try to make it better next time.
    15362
    SidneyABBR
    If You code is like this "G3 then it is not going to run, you will have to remove all the ( " ) from any lines of code, or they will not run
    Your Z move may be a problem also, this may have to be on a separate line, but for what you are doing it should work ok
    Mactec54
    15362
    SidneyABBR
    Just noticed that you have the ( " ) at the beginning & End of each Block, this can not be there, seems that your post processor needs some work
    Mactec54
    Jun 2014
    27
    SidneyABBR
    The (") it's just to separate the code from the rest of the text on the post. The g-code file don't have them, you can see the original file on the first post.
    I need to check on the file but, I think that there is more moves like this before the error.
    Thanks for the help.
    15362
    SidneyABBR
    The code that you posted runs fine, so like you said there may be something before these blocks, not everyone can open the file in your first post, it's always better to post it as text, then anyone can open it
    Mactec54
    Jul 2003
    1766
    What version of mach? What is your ma velocity/accel in your config?
    I don't see an issue here with V.043
    maybe related to
    This GCODE make my cnc motor loosing steps
    sam
    Jun 2014
    27
    SidneyABBR
    I tryed to post the files as simple text files but the size of files is larger than the forum limit. I'm a fool, I forget the tools we have today, I put the files on google drive now everyone can access them, following the links:
    https://drive.google.com/file/d/0B_h...ew?usp=sharing
    Have you tested the code by software or making the machine run? On mach3 simulation everything its ok but when the machine runs the problem shows up.
    Jun 2014
    27
    Quote Originally Posted by samco View Post
    maybe related to
    sam
    I need to check the version. But I have the .xml file saved on line here´s the link:
    Thanks.
    Jun 2014
    27
    Quote Originally Posted by SidneyABBR View Post
    Thanks.
    Version 3.042.020
    Enviado de meu SM-G900M usando Tapatalk
    Jul 2003
    1766
    If you read the link I posted - .042 seemed to have some issues with stalling on certain moves.
    15362
    SidneyABBR
    There could be a lot of things happening, is your machine up to moving short moves at 2000mm/per/min, this may be where your problem is, feed rate, or acceleration settings set to high for your machine
    You should not have a G49 in your program, this will cancel your tool offset
    Using G91 to move the Z axes to 0 is not so good also, if your are programing in G90 absolute, then you want to keep your moves in absolute ( G90 ) wherever you can
    To move your Z to 0 just use G0Z0 is all that is needed or G0G53Z0
    There are some Z moves in the program that don't make any sense also,
    The program run right through with Mach 3 running, but I did not cut anything, so don't know if it missed any Code, it did look complete on the screen
    What cam program are you using
    Mactec54
    Oct 2005
    1145
    Yes Mach3 CAN skip lies BUT it it is not really Mach3 doing it. These are the 4 things I have seen cause it.
    Hard drive bad sector bit
    Memory bad sector bit
    Currupt Gcode file.
    Rogue hidden charector in Gcode file
    Almost forgot one Pirated License (;-)
    Have you tried recamming the same project and see IF it reoccurs with a new file ??
    (;-) TP
    35494
    It looks like it's skipping the spiral leadin move. Moves similar to this are known to cause lost steps due to a bug in Mach3.
    Try isolating the bad section of code to maybe 100 lines before to 100 lines after, and run it with Feedrate Override at maybe 10%. If it runs OK, keep increasing the FRO back up until you get to 100%.
    Oct 2005
    1145
    Looking at your XML file I see we may have friends in common. Do you know Ivan Todosijevic ??
    (;-) TP
Page 1 of 2 12
  1. G code line jump?
    By Epiphany in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-03-2016, 09:18 PM
  2. Only running three lines of code
    By OCNC in forum NCPlot G-Code editor / backplotter
    Last Post: 02-13-2011, 10:09 PM
  3. 99999 max lines of code?
    By dingo0722 in forum Haas Mills
    Last Post: 12-17-2010, 01:43 AM
  4. Repeat G-Code lines
    By rckdef in forum G-Code Programing
    Last Post: 07-22-2010, 09:00 AM
  5. Only getting 48 lines of code?
    By Crawler374 in forum Mach Software (ArtSoft software)
    Last Post: 09-25-2009, 03:54 AM
