586,103 active members*
3,298 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Mitsubishi VMC with Fanuc Series 21M
    Dec 2006
    310
    Dear Sirs
    Recently we have replaced X axis ballscrew with new one and since then we are finding hole size variation in the job (Tolerance is upto 30 microns). Backlash values are almost negligible for all three axes ie +/-1
    We are doubting pitch of new ballscrew and may be there is difference of about few microns between old and new ballscrews, which we need to compensate
    Kindly let us know how to give compensation for change in ballscrew pitch
    Warm Regards
    Jun 2010
    4256
    Re: Mitsubishi VMC with Fanuc Series 21M
    Function Config / Screw Mapping
    But also check whether you have an imperial or metric leadscrew.
    Cheers
    Roger
    Dec 2006
    310
    We are using metric ballscrew having pitch of 5mm
    Please explain what u meant by Function Config/Screw mapping
    Jun 2010
    4256
    Apologies!
    I was assuming you are running Mach3.
    Doesn't your Fanuc have 'screw mapping'? I don't know how the Fanuc stuff is calibrated.
    Mind you, I would still be looking at the quality of the ball screw and ball nut, and the bearings. 30 microns is a lot of error.
    Cheers
    Roger
  1. Mitsubishi MV Series Wire EDM
    By william18 in forum EDM Discussion General Topics
    Last Post: 10-18-2019, 06:45 PM
  2. Mitsubishi MV4C VMC with Fanuc Series 21M
    By M.RISHIKESH in forum Fanuc
    Last Post: 09-08-2015, 06:45 AM
  3. Mitsubishi SB series EDM Parts
    By dogwood8488 in forum EDM Discussion General Topics
    Last Post: 12-20-2013, 01:00 AM
  4. MITSUBISHI MELDAS 500 SERIES
    By el gordo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2013, 12:33 PM
  5. Mitsubishi FA Series Wire EDM
    By supercrewed in forum EDM Discussion General Topics
    Last Post: 08-20-2008, 03:21 PM
