586,076 active members*
3,912 visitors online*
    Sep 2015
    Question Solidcam stock-target problem
    Hello,
    I have problem with merging stock and target. Stock is imported with STL file, target is normal part. The problem is shown on picture. Coordinate system on target and stock is on the same place.
    Please help me if anyone knows how to solve this problem.
    Sep 2015
    Re: Solidcam stock-target problem
    I solved it with using two configurations in the same part. One as target and other as stock. Now I have little problem with tool path. That is on some diameter, not on the surface. I tried a lot of different things, but without success. On contour I set the curve is wrapped around X axis. It looks like the Z level is constant whole time.
    What can I do to solve this?
    Best regards,
    Kristjan
    Oct 2013
    153
    Use a multi axis operation
  1. Solidcam stock-target problem
    By kpidler in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-22-2015, 05:57 AM
  2. Solidcam 2014 PROBLEM
    By tano in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-24-2014, 09:10 AM
  3. Need help! Solidcam machine simulation-stock problem
    By shadow2303 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-05-2014, 12:43 PM
  4. GPPTool variables for Stock and Target definition
    By jauki in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-05-2011, 07:59 AM
  5. SolidCam Radius Problem
    By CNCOX in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-10-2009, 05:37 AM
