586,876 active members*
3,284 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Predator DNC not closing thread after transfer from Predator to CNC machine
Results 1 to 2 of 2
    Sep 2010
    3
    Predator DNC not closing thread after transfer from Predator to CNC machine. The program goes through, it's present on the CNC. However, the transfer arrow is displayed next the machine icon in Predator. This creates a problem because when the machinist try to upload from the same CNC to Predator it doesn't work. He was to log into Predator and cancel the transfer then upload works fine. What should I look for first?
    Also, the problem is intermitten too, sometimes it transfers completely and sometime it stucks open.
    Jul 2004
    173
    Re: Predator DNC not closing thread after transfer from Predator to CNC machine
    Quote Originally Posted by bunta View Post
    You could check to make sure you program is properly formatted for the CNC. More than likely, there is data (spaces, comments, other non-readable characters) after the M30, precent sign. If you remove this, then Predator will understand no other data is to be transmitted to the machine.
    The other option, add a "clean code" object into the Send command you are using and select - send % to % only. This will remove the characters for you automatically.
    Hope this helps but if not, give us a ring and we can help narrow down the problem.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
  1. Predator Editor TNc 155 Data transfer
    By guyiknow in forum Computers / Desktops / Networking
    Last Post: 10-12-2015, 03:12 AM
  2. predator missing menus-predator v7
    By ricowind67 in forum BobCad-Cam
    Last Post: 10-08-2012, 03:23 PM
  3. DNC transfer to Dyna's via Predator WORKS!
    By Fastest1 in forum Dyna Mechtronics
    Last Post: 08-28-2010, 10:30 PM
  4. Does Predator allow a file transfer via DNC?
    By Fastest1 in forum DNC Problems and Solutions
    Last Post: 08-24-2010, 01:48 AM
  5. Predator hook up to swiss machine
    By tejano4life72 in forum CNC Swiss Screw Machines
    Last Post: 12-03-2007, 07:24 PM
