603,781 active members*
2,465 visitors online*
IndustryArena Forum > CAM Software > Esprit > Esprit - Changing post processor to X-axis diameter mode
Hybrid View
    Nov 2008
    51
    I have a Y-axis lathe post processor I am using on a Mori Seiki SL154Y. I need to change the X-axis to post diameter instead of radial. The Y-axis is fine and posting radial which works on my machine. Anyone know how to change the X -axis? Or does anyone have a good Y-axis post for Mori I can try out.
    2932
    Re: Esprit - Changing post processor to X-axis diameter mode
    It's on the Assembly tab of the SolidTurn Machine Setup page, Set Radial Output to Diametral.
    Nov 2008
    51
    dcoupar,
    Thanks, I added to the post "Machine Modes" section RADIALVALUEMODE : DIAMETRAL like you said and it worked beautifully. The machine set up page is now Diametral.
  1. Replies: 5
    Last Post: 04-02-2024, 01:54 PM
  2. Need a Esprit post processor
    By Xecus in forum Esprit
    Last Post: 04-02-2024, 01:53 PM
  3. Replies: 0
    Last Post: 07-01-2015, 09:05 AM
  4. Need Help! Post Processor iTNC530 - Esprit
    By Medvecky2000 in forum Post Processors
    Last Post: 11-24-2013, 12:53 AM
  5. changing a post processor
    By fourperf in forum Fadal
    Last Post: 06-16-2007, 04:48 PM
