603,929 active members*
2,904 visitors online*
IndustryArena Forum > CAM Software > Mastercam > surface toolpath
Results 1 to 19 of 19
Threaded View
Julian M surface toolpath 12-08-2006, 05:25 PM
Matt Berube In my opinion the easiest way... 12-08-2006, 10:19 PM
ObrienDave Try something like these... 12-09-2006, 02:03 AM
Julian M Thanks for this i really... 12-09-2006, 07:16 PM
Matt Berube Mastercam will never violate... 12-09-2006, 09:20 PM
Julian M Your a genius what would i do... 12-09-2006, 09:45 PM
ObrienDave Julian, One of the hardest... 12-09-2006, 11:19 PM
cadcam Julian waht version of... 12-09-2006, 11:01 PM
Julian M Hi cadcam i am running MC-X... 12-09-2006, 11:23 PM
Matt Berube For me, that is the golden... 12-09-2006, 11:42 PM
cadcam Julin here it is in MCX-mr2,... 12-09-2006, 11:46 PM
Julian M Thanks all of you for helping... 12-10-2006, 03:08 PM
ObrienDave Julian, Unfortunately, you... 12-10-2006, 04:11 PM
Julian M Dave, how would i do this if... 12-10-2006, 04:36 PM
Matt Berube Julian, do you have solids ? 12-10-2006, 04:07 PM
Julian M Matt, i only have this part... 12-10-2006, 04:27 PM
ObrienDave Your quite welcome. Glad to... 01-06-2007, 12:53 AM
    Sep 2006
    69
    Question surface toolpath
    The attached file is a casting for which im trying to use surface toolpaths to machine the face which is 2mm down from the outside face, which has the 5.5mm slot through it, the surface is green(not the recess around the open face) I have tried using high speed horizontal toolpath with little success. Any help would be gratefully received
    Thanks Julian
    Attached Files Attached Files
