Re: Stepper motor assistance
That is a 12 volt supply?
With stepper motors, more speed = higher voltage. As I understand it, the K179 will go up to 36 volts? I'd recommend trying a 24 volt supply.
Of course, that is a very limited driver... You might do better with another driver... but NOT a TB6560 based unit... Please! Those are horrible.
And we don't know much about the motor. How many wires? What current rating?
Another possibility: Use a mechanical solution to produce faster motion. E.g. a gear or belt drive. Steppers have more torque at low speeds. You can trade some of that for speed via a drive system.
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
