Originally Posted by
jmsiefer
The USB CNC board lists terminals for the X-Axis as: |CP|CW|-|+5|
On the "A931A CNC Router Single Axis 3.5A TB6560 Stepper Stepping Motor Driver", one side has terminals listed as: |-voltage input|+voltage input|B-|B+|A-|A+|.
I connected a stepper motor with Red, Yellow, Black and Grey wires to these contacts as follows: I connected the Red wire of the stepper motor to |B-|. I connected the Yellow stepper motor to |B+|. I connected the Black wire to |A-|. I connected the Grey wire to |A+|.
On the opposite side of the "A931A CNC Router Single Axis 3.5A TB6560 Stepper Stepping Motor Driver", the terminals are: |+V|Pul-|Dir-|EN-|.
I ran a wire from |+V| on the Motor Driver to |CP| on the USB board. I ran a second wire from |Pul-| on the Motor Driver to |CW| on the USB board. I ran a third wire from |Dir-| on the Motor Driver to |-| on the USB board. And then last, I ran a wire from |EN-| on the Motor Driver to |+5| on the USB board.
Like I said, the motor "seems" to run correctly, but it's only driving in one direction. Very odd.
