587,998 active members*
2,495 visitors online*
Thread: Code editor
Results 1 to 7 of 7
Hybrid View
    Oct 2014
    30
    Code editor
    Anyone have any experience with a free code editor that will check code for syntax errors? I have been using G-Wizard Editor from CNC Cookbook, and it is outstanding. It checks and advises how to fix code problems, but I just can't justify the expense of an annual subscription for what little machining I do. Most everything I do right now is simple enough that I can use the Mach 3 teach mode to get stuff done, but sometimes I need something a little more complicated. MeshCam doesn't always turn out Mach 3 ready code, so I have used GWE to check and correct it. Now that my subscription has run out, I am looking for something similar that is free, or at least inexpensive.
    Any advice out there?
    Aug 2006
    673
    Re: Code editor
    Sounds like you really just need a better post!
    HSMworks comes with a free post editor and is free to download.
    You might also look into cncwrapper. Not only is it cheap and give you the ability to wrap gcode around an axis, but it has a built in gcode editor.
    I'm not usre if either of those will help fix errors, but i think they will both identify non-standard code.
    Oct 2014
    30
    Re: Code editor
    Thanks. Will give both a look.
    1943
    Re: Code editor
    Notepad++ is a customizable text editor. There is a plug in for Notepad++ that does g-code. What it does is syntax color coding of the G-code file.
    https://notepad-plus-plus.org/
    1943
    Re: Code editor
    Don't know if you found one yet, but I found the one in the link below and it appears to do an excellent job. I have only just tried it briefly though. And it's free.
    NC Corrector, free G-Code editor.
    Feb 2006
    7063
    Re: Code editor
    Quote Originally Posted by 109jb View Post
    That one shows some promise, but is currently kinda buggy. On my G-code, it shows the execution time of a 5 minute program as one second. It also seems to only understand metric - there doesn't seem to be an option to set Imperial units and it seems to ignore G20/G21.
    Regards,
    Ray L.
    Oct 2014
    30
    Re: Code editor
    My anti virus won't let me open that page.
  1. G-code editor?
    By gearsoup in forum G-Code Programing
    Last Post: 11-28-2011, 03:06 PM
  2. G code editor for MAC
    By DIFF OVER in forum Uncategorised CAM Discussion
    Last Post: 10-28-2010, 01:21 AM
  3. G Code Editor
    By TravisR100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-30-2009, 02:18 AM
  4. NC code editor
    By grimy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-07-2009, 04:57 AM
  5. Looking for g-code editor
    By avengine in forum Community Club House
    Last Post: 04-28-2006, 07:01 PM
