586,055 active members*
4,280 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Master/Slave X axis side swap - does it matter?
    Apr 2004
    326
    I decide to mount my E-track and trays on the right hand side of the X axis, as opposed to the right side which is shown in the instructions no the CNC router parts site.
    I did this because it exposes the slots for opening the E-track and makes it easier.
    The question is, does it matter which X-axis motor is hooked up a "X" vs "A"? Should X still be on the left, with A on the right, or is it just a matter reversing the settings in Mach3? Thinking that switching them will make them move in the opposite direction from "normal" ?
    Thanks.
    Jun 2013
    88
    Re: Master/Slave X axis side swap - does it matter?
    Quote Originally Posted by Kosh View Post
    Hi Kosh, While you can certainly configure the machine with either X axis being X vs A (Slaved), I recommend staying with the documented convention regardless of where you install the cable trays.
    Thanks!
    -Nathan
    Jun 2004
    6618
    Yeah, you can run into trouble with homing the machine and trouble shooting assistance later on. Maybe even cable issues as below. I ran my slaved wire through the gantry along with the Y+ sensor.
    Regarding the cable track though, a small bent wire will pop those holder up. Long small allen wrench too. They snap snug, but pop open easy with just the right leverage.
    I can tell you that you will want that echain as close to your control box s you can get it comfortably. Most of the cables are plenty long, but I ran into an issue with the network cable and one of my motor cables was too short for my configuration.
    I need 3 20' and one 12' for the PRO 4824.
    Lee
    Apr 2004
    326
    @leeway
    Was thinking a paint can opener would work well too
    Jun 2004
    6618
    That might do. An angled awl would work or even a lock picking set. Not that I have one of those.
    In fact, I have the perfect tool for it. I haven't used it before and it came in some elcheapo set years ago. an angled screw driver.
    Lee
  1. Trying to swap slave axis
    By landarts in forum Avid CNC
    Last Post: 04-13-2015, 05:36 AM
  2. Replies: 0
    Last Post: 11-27-2012, 11:45 AM
  3. CNC Master and Slave problem
    By cambridgecnc in forum CNC Machine Related Electronics
    Last Post: 12-01-2010, 04:04 AM
  4. master-slave servos
    By js412000 in forum Servo Motors / Drives
    Last Post: 03-09-2007, 07:36 AM
  5. Master and Slave servo
    By Builder in forum Servo Motors / Drives
    Last Post: 11-02-2004, 03:55 PM
