586,077 active members*
3,827 visitors online*
    Aug 2015
    charmilles robofil 290
    E635:OVERFLOW V-DEVIATION
    No axis reference ?
    Jun 2009
    11
    Re: charmilles robofil 290
    From my manual.
    E635 Overflow V-Deviation Check: - that the table motion is not blocked
    - that the displayed position is correct
    Restart operation. Persisting symptom means failure.
    I'm guessing you crashed/Jammed the the head or possibly a motor coupling came loose. My understanding is the error is from the control thinking the machine should be in range of a certain location and from reading scales it has determined it is outside of that range. I'd shut it down and make sure the axis slide moves freely and nothing is jammed and restart it.
    I also guess at the the time of this error it clears the axis home reference.
  1. Charmilles Robofil 510 Aux codes
    By tallenttoolroom in forum Waterjet General Topics
    Last Post: 04-27-2020, 09:41 AM
  2. Charmilles Robofil Wire Edm
    By sundara in forum EDM Discussion General Topics
    Last Post: 08-01-2017, 09:56 PM
  3. DNC CHARMILLES ROBOFIL 310
    By tecnomaqq in forum EDM Discussion General Topics
    Last Post: 01-17-2014, 04:34 AM
  4. charmilles Robofil 190 or charmilles Robofil 290
    By Fontez in forum Post Processors for MC
    Last Post: 03-12-2013, 04:48 PM
  5. Charmilles Robofil 300 question
    By rtuls35 in forum EDM Discussion General Topics
    Last Post: 06-15-2011, 06:09 PM
