586,679 active members*
2,741 visitors online*
IndustryArena Forum > CAM Software > OneCNC > One Cnc XR4 Problem Lathe
    Hi all.
    My problem is the cycle time on Xr4.
    When i turn a length in Z-, then go onto job sheet, the cycle time is out.
    Example
    If i turn 20mm long at 1000rpm .1 feed rate, i should get 12 secs.
    One cnc job sheet gives me 23 seconds.
    Has anybody got any ideas?
    Thanks in advance.
    Ash
    927
    Re: One Cnc XR4 Problem Lathe
    Ash,
    I get 12 seconds here with your example settings.
    That is with the default post.
    You sure you don't have a second finish pass set ??
    You could post your sample file to look at.
    Angry Re: One Cnc XR4 Problem Lathe
    Quote Originally Posted by wms View Post
    Ash,
    Hi
    I only have 1 pass.
    Also, if i drill with the same spindle speed and feed rate i get the same time on the job sheet as when i turn?
    I have been through all of the settings and cant find anything that would cause this.
    Thanks for your input )
    Regards
    Ash
  1. CNC lathe: Run-out problem
    By haklc in forum Uncategorised MetalWorking Machines
    Last Post: 02-05-2015, 10:39 PM
  2. V25 lathe Problem
    By kawman in forum BobCad-Cam
    Last Post: 07-18-2013, 10:00 PM
  3. Lathe problem
    By Pressco in forum Mastercam
    Last Post: 08-11-2011, 08:36 PM
  4. new lathe problem
    By tjd10684 in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2011, 04:21 PM
  5. Excel 500 Lathe Problem
    By theanswers in forum Uncategorised MetalWorking Machines
    Last Post: 05-17-2010, 04:29 PM
