586,116 active members*
3,366 visitors online*
    Dec 2015
    Zeroing Issues In Mach 3
    I bought a used CNC mill (Franklinton) and I'm using Mach 3 in Win XP to cut holes in plastic cases. I have a jig allowing me to cut 3 cases at a time. I have much to learn.
    After some adventures with the wobbler, I have the cutting tool zeroed, and it is cutting holes in the right places. But after a short time, Mach 3 (and XP) lock up, and I have to do a hard reboot. The locking up is a separate issue - I see lots of people have that problem with Mach 3.
    My question is - when Mach 3 locks up -- I take note of where the X, Y and Z are. Example from the last lockup:
    X is +3.8003
    Y is -.5068
    Z is - .0754
    After rebooting the PC - is there a way to "re-enter" those coordinates in Mach 3, then click "Go To Zero" and have it go back to my zero point -- saving me from further fun with the wobbler?
    Since I'm not very good with the wobbler -- I can never get the tool zeroed at precisely the same point as pre-lockup. The result - I ruin another plastic case, at $4 each.
    Once I have the tool zeroed properly -- how can I return it to zero when Mach 3 locks up? Thanks for any help!
    Re: Zeroing Issues In Mach 3
    I would figure out why Mach3 "locks up", and fix it. It never has for me, and doesn't for most people.
    Dec 2015
    I haven't been able to determine why Mach 3 locks up. There is nothing on the PC but XP and Mach 3. I ran the PC for days without Mach 3 running, with no issue - so I assume it's not a PC hardware issue, and it's not a Windows issue. I have searched extensively for solutions. All I found is a suggestion that possibly power fluctuations might cause the locking up. So I am running the PC on a different outlet from the CNC mill. That cut the lockups by perhaps 20%.
    So - I assume there is some issue with Mach 3 (A search shows a huge number of people have the same locking up issue I do). Which leaves me to deal with the problem in another way:
    How can I enter the last coordinates that are listed when Mach 3 locked up - and zero the tool based on those coordinates? Thanks for any help!
    After you zero the X, Y abd Z axis, go to the offsets page and save the offsets.
    Then, when you restart Mach3, just home the axis and you should be good to go.
    Provided you have accurate home switches.
    Dec 2015
    Thank you for the information. I don't know how to do that, but now I know what to look for in the docs. I appreciate your help.
  1. Mach 3 and homebuilt CNC issues
    By muuse in forum DeskCNC Controller Board
    Last Post: 08-18-2014, 02:26 AM
  2. Mach 3 Y-Axis Issues...
    By abomb55076 in forum Mach Software (ArtSoft software)
    Last Post: 04-08-2014, 02:02 PM
  3. Zeroing axis on Mach 3?
    By jimmy5 in forum Mach Software (ArtSoft software)
    Last Post: 08-27-2012, 06:29 AM
  4. Need help mach 3 and madcam issues
    By stevewebster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-13-2009, 03:54 AM
  5. Mach 2 set up issues
    By randyb47 in forum Mach Mill
    Last Post: 11-29-2007, 06:02 AM
