603,896 active members*
4,848 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Start from line - error: Radius difference too large between start and end of arc
    Oct 2009
    23
    Hello, today I was running a few parts on my Tormach 1100 with path pilot and wanted to skip a few operations in my g code. I found where I wanted to start from and kept getting this error when trying to run. I tried selecting many different lines near the part of the file I wanted to start at and kept getting the same error. What does it mean? This is a file I just got done running start to finish moments before. I basically wanted to skip a few hole drilling operations and go straight to milling the outside countour of the part. Every line segment of the contour I selected I would get this error..I managed to work around it but it was annoying and want to know for future
    Aug 2007
    701
    Re: Start from line - error: Radius difference too large between start and end of arc
    I get that same error all the time. Using the Fusion 360 post processor. Usually I ignore the warning and the code runs fine. But I haven't really started in the middle of a tool path.
    Jul 2003
    1766
    If you use 'start from' and you start on an arc (g3,4) you would have to be in the correct location for the start of that arc. (so if there are a bunch of G2,3's in a row - it would be very hard to start unless the tool was exactly at the starting point of the given arc)
    Jul 2004
    1424
    I am betting the problem is the Z position at the start of the arc. I have ran unto this before when I have edited g-code during operations. If you put a G01 Z height command at the start of the arc that is the same height as the arc Z height, it should solve this.
    Essentially, what has happened is the lines of g-code you commented out changed what the z-height of the spindle was when it reached the commanded arc. Now the arc move in XYZ is too large where before with a smaller difference in Z it could make the cut.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Jan 2025
    Betting has evolved significantly with the advent of online platforms, making it more accessible and convenient. Whether it's sports, casino games, or fantasy leagues, the digital era has brought opportunities for enthusiasts to engage in their favorite activities from anywhere. Platforms like https://videogenie.com provide innovative ways to explore betting trends, offering insights and tools for better decision-making. Responsible gambling is essential to ensure the experience remains enjoyable and within limits. By staying informed and leveraging technology wisely, bettors can enhance their skills and make more informed choices. The right resources can turn betting into a fun and strategic pastime.
  1. Radius to end of arc differs from radius start
    By Don C in forum Dolphin CAD/CAM
    Last Post: 06-29-2014, 04:46 PM
  2. 021 start radius end radius error
    By XAD in forum Tree
    Last Post: 06-01-2012, 04:59 PM
  3. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  4. Replies: 8
    Last Post: 11-15-2009, 01:35 PM
  5. Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 05:28 AM
