603,942 active members*
3,334 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 3 Axis CNC TB6560 Stepper Motor Driver Board Controller - Toshiba TB6560AHQ - scheme
Results 1 to 12 of 12
    Mar 2014
    6
    Before all, Happy New Year.
    I search on this site electricall scheme of this driver, but I can not find. If is not problem to reply me link of cnczone's post where is scheme, or link from internet ? For me it is very important, because I must to control step motors with Arm7 microcontroller.
    Thank you in advance
    Apr 2004
    5951
    Re: 3 Axis CNC TB6560 Stepper Motor Driver Board Controller - Toshiba TB6560AHQ - sch
    You might find this thread helpful: http://www.cnczone.com/forums/genera...-software.html
    Andrew Werby
    Website
    Mar 2014
    6
    Quote Originally Posted by awerby View Post
    Thank you, I search there, but I can not find
    Mar 2014
    6
    Can anyone help me ?
    Mar 2009
    533
    Maybe, ... but I'm not clear what you are asking.
    Do you have a TB6560 board but don't know how to connect your motors to it?
    Do you have an ARM7 board that needs to interface with the TB6560 board?
    Is it motor wiring diagrams you are looking for?
    Limit switches wiring?
    Power supply wiring?
    Please provide more details.
    Mar 2007
    2083
    when I looked at the 3 & 4 axis TB6506 boards I was left with the impression designers arranged the connections to the printerport connector to make the routing of the PCB tracks easier
    there is no guarantee boards from different manufactures will have assigned the same functions to any particular pin
    you will need the manual for your board to be able to connect it to the "printer port" the Arm7 microcontroller emulates
    John
    Mar 2014
    6
    Quote Originally Posted by john-100 View Post
    John
    Thank you for your reply.
    I know what to do with Arm7, but problem is with tb6560, because i do not know how to connect ''lpt port'' from tb6560 to Arm 7. I need help for driver, help for pins of comunication. Maybe lpt port is made for selling. simple business plan,
    Quote Originally Posted by KOC62 View Post
    I know to connect motors on the board.
    Yes, I would like to connect Arm 7 with Toshiba TB6560 driver. To control or send G code from Arm mcu to this driver.
    TB6560 has 2 ports, LPT and Manual. For this I need schematic of TB6560 board, and I must see for what is used 15 pins from manual port, and 25 pins from lpt port.
    Mar 2009
    533
    OK, we are getting somewhere now.
    Understand that there are many variations of a TB6560 as they all use a TB6560 chip, but could use a different pinouts.
    You didn't give us the model number of your board. Did it not come with a manual?
    Here is an example that may not be the same as yours; http://www.fut-electronics.com/wp-co...ers_Manual.pdf
    An example of a 3-axis TB6560 board; http://www.cncgeeker.com/images/manu...eCNCGeeker.pdf
    Mar 2014
    6
    Attachment 303454
    I have this board, I do not know where is model number ?
    CHIP : TOSHIBA TB6560AHQ
    Mar 2007
    2083
    it could be this one
    Mar 2009
    533
    Now follow the manual that john-100 gave you including the use of Mach 3. If you get the motors working you can then try your Arm 7 setup.
    Mar 2014
    6
    Thank you, thank you, thank you !
  1. Problem with CNC 4 Axis 3.5A TB6560 Stepper Motor Driver Board
    By bbbharvard_cnc in forum CNC Machine Related Electronics
    Last Post: 07-16-2024, 06:24 PM
  2. 'New' 4 axis TB6560 stepper motor driver CNC controller board
    By Doronby in forum Stepper Motors / Drives
    Last Post: 02-22-2012, 04:29 PM
  3. 4 Axis TB6560 CNC Stepper Motor Driver Board Controller with a GGC usb
    By RCjunkie in forum CNC Wire Foam Cutter Machines
    Last Post: 01-24-2012, 04:45 PM
  4. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
