603,378 active members*
3,055 visitors online*
    May 2005
    674
    Plasma: Machine vs Hand Torch
    Other than ease of mounting, what are the benefits of a machine torch over a hand torch?
    My main concern is that the machine torch seems to really limit the max workpiece thickness. I was looking at the 1000 and 1250 Hypertherms and was hoping to cut the occasional 1" thick piece, but it doesn't look like that'll happen with a machine torch.
    24260
    Quote Originally Posted by Zumba View Post
    One thing being water cooled for higher duty cycles.
    Al.
    Albert E.
    May 2005
    674
    Ah, watercooling is important. Does that mean that the power unit has a pump installed when a machine torch package is purchased?
    Dec 2006
    62
    Machine torches are generally 100% duty. But, this shouldn’t stop you from jury-rigging a handheld torch to your machine when you do need to cut that thick plate.
    26
    Machine torch enable us to change or clean the nozzle and electrode more easier than hand torch.
    But I don't think the performance of cutting thickness is different if compare hand torch and machine torch.
    The Hypertherm 1250 with machine torch can cut 1" mild steel if you cut from the edge. But you need to spend more money to replace the consumable if you are using machine torch above their recomended thickness 5/8".
    Joe
    AC MECA
