586,242 active members*
3,787 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > NEED - Air Deflector for Bosch 1617evs?
Results 1 to 7 of 7
    Aug 2011
    107
    Anyone make one and willing to share? I could even 3d print one if that is what you have. I would like to avoid re-inventing the wheel if possible.
    I just finished assembling my first machine (CNCRP Pro4824) and after a test cut of the Mach3 Roadrunner I most definitely need one, lol.
    Mar 2017
    250
    Re: NEED - Air Deflector for Bosch 1617evs?
    Quote Originally Posted by SixOfOne View Post
    Did you ever find one? I'm looking now, might have to design it myself if not.
    Sent from my SM-N950U using Tapatalk
    Apr 2009
    5516
    I just took some Plexiglas, drilled a hole for the bit to pass, and mounted it such that it stays stationary while the carriage moves (threaded rod mounted to frame of carriage through a couple drilled blocks to make the height adjustable.)
    Aug 2011
    107
    I actually did end up 3d printing one. I will see if I still have the STL for it (on an old PC) an upload it somewhere.
    It was great at keeping the router exhaust from throwing chips and dust everywhere but It didn't last long. After a week of following the bit with the shopvac I bought a dust collector and made a shoe. Dust shoe without deflector works better bc the Bosch blows chips away from the cut area and the shoe sucks umm up.
    Mar 2017
    250
    I have a shoe, but the exhaust blows things around enough that the dust collector doesn't get as much as it could. I want to force the exhaust towards the cutter on one side so that it blows it towards the dust port mainly instead of every direction. Might not work how I envision it, but I'm going to try anyway.
    Nov 2014
    20
    I'm interested in this subject too. If anybody knows of a CNC or 3d printed model, please post a link.
    Thanks!
    John
    Dec 2014
    640
    I have the same issue with my Makita RT0701C cpmact trim router. I cut out a deflector and mounted it at an angle to deflect the air away the work piece. It's kinda crude but it works...
  1. Replies: 6
    Last Post: 01-18-2015, 06:04 PM
  2. Dust boot for Bosch 1617EVS router
    By mickelsen in forum DIY CNC Router Table Machines
    Last Post: 07-09-2010, 03:40 PM
  3. Bosch 1617evs wiring under cap?
    By Dan Craig in forum DIY CNC Router Table Machines
    Last Post: 04-21-2009, 03:32 AM
  4. Need a 1/8 collet for mt Bosch 1617EVS
    By OneAndy in forum Want To Buy...Need help!
    Last Post: 10-21-2008, 12:05 AM
  5. Bosch 1617EVS
    By phantomcow2 in forum DIY CNC Router Table Machines
    Last Post: 04-04-2006, 04:29 AM
