586,096 active members*
3,721 visitors online*
    Jul 2008
    17
    Cutting Steel Parts
    Hi Folks,
    I am well into my build for the machine and have completed most of the wood and aluminum parts. Just wondering about cutting the steel parts. I purchased a metal cutting band saw blade for my machine and it works well on the aluminum. The steel parts are a different story. Do you really cut the lengths with a handsaw, zip drill holes and cut out and file the odd shapes, or is there a simpler way to obtain the geometry in the plans? Thanks in advance.
    Dec 2012
    62
    Re: Cutting Steel Parts
    Yes you can do it with only a file and hacksaw and lots of elbow grease.
    Mar 2012
    19
    If you are using a wood cutting bandsaw the blade speed is way to fast for steel, even with a good bi metal blade. For mild steel you want a blade speed of around 200 fpm. The ideal speed for aluminum is something like 400-1000 fpm, but you can get by at wood cutting speeds (2000-4000 fpm) without ruining the blade. I have an old craftsman three wheel bandsaw that I slowed down to metal cutting speeds and it cuts steel quite well with a bi metal blade.
  1. Need Offer for cutting mirror stainless Steel Parts
    By Kosmas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-17-2014, 01:56 PM
  2. Need Offer for cutting mirror stainless Steel Parts
    By Kosmas in forum Want To Buy...Need help!
    Last Post: 08-09-2014, 10:23 AM
  3. LIMAC fiber laser cutting machine for stainless steel cutting video
    By limacchina in forum Fiber Laser Cutting Topics
    Last Post: 05-05-2013, 05:24 PM
  4. Cutting small parts in stainless steel
    By etur in forum Benchtop Machines
    Last Post: 11-15-2010, 10:25 PM
