586,096 active members*
3,364 visitors online*
IndustryArena Forum > SignMaking > Portfolio Board > Zombie Response Unit Sign
Results 1 to 9 of 9
    Here is a project I designed, a Zombie Response Unit Sign.
    It's a relatively simple sign but using a variety of materials.
    We will have Dimensional Cut-Out letters using Dibond which will be either inlayed or more than likely stand-off on to a wood back piece.
    The O in the word Zombie will be like a gun scope aimed at... what else a zombie lol.
    The scope will be made of Clear Acrylic, Carbon-Fiber and Red Sticker Vinyl on a piece of white Plastic.
    Also the word RESPONSE UNIT will be Carbon-Fiber and inlayed into the wood.
    The Zombie Response Unit Sign will be 6" High and 22" Wide.
    will be using a Vision 2550 CNC Router for this project.
    I will be posting photos and possibly videos of our progress with this project.
    Attachment 303802
    Dec 2007
    2134
    Re: Zombie Response Unit Sign
    I like it!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Here are some photos of the wood back piece of the Zombie Sign.
    Drilled the holes for the standoffs with the router head
    Attachment 303872
    Routed out the shape of the back piece
    Engraved out letters where we will be inlaying Carbon-Fiber with the engraving head
    Routed out the center "O" circle where the acrylic scope with zombie graphic will be placed
    Removed the dust collection boot from the 2550 CNC Router to show a better photo :-)
    Here is the final back piece for the Zombie Response Unit Sign
    Here are photos of the Dibond we routed out on the Vision 2550 CNC Router
    Dibond is a brand name of a material consisting of a solid piece of polyethylene (plastic) sandwiched between two sheets of thin aluminum. This make for a rigid aluminum like material but lighter.
    Here we added countersinks for the standoff screws
    Attachment 304002
    Close up of the countersink for the standoff screws
    Attachment 304004
    Routed out the letters. Removed boot for a better photo
    Attachment 304006
    Close up of the cutting tool
    Attachment 304008
    CNC Routed letters in the Dibond
    Attachment 304010
    Here are some of the Routed Dibond letters cleaned up a little
    Attachment 304012
    Here are photos of the "O" in the word Zombie, we routed and engraved various materials to give it a dimensional look.
    It's supposed to be a rifle scope aiming at a zombie.
    First layer is a Zombie Graphic made from sticker vinyl on plastic.
    We used Print-To-Cut system and an engraving head, basically a camera sees the dots/ registration marks on the application and uses it to cut-out a perfect circle around the Zombie graphic.
    Attachment 304550
    Second layer is a routed out half inch piece of clear acrylic, we switched to a routing head for this.
    It's a big mess because again we removed the dust collection boot from the 2550 CNC Router to show the area being routed.
    Attachment 304554
    Attachment 304556
    Third layer is the Carbon Fiber cross hairs.
    It's important to note, if your going to work with Carbon Fiber, use gloves and a mask.
    You don't want to inhale the fibers or get it on your skin.
    Attachment 304558
    We also did the Carbon Fiber letters that are going to be inlayed into the wood backing for the sign.
    Attachment 304560
    Attachment 304562
    Forth layer is a plastic part that we added and was not in the original design, this part will help hold down layers 1, 2, & 3.
    Attachment 304564
    Attachment 304566
    The Fifth layer will be the Dibond letter "O" that we routed out earlier in the project.
    Here are a photos of all the pieces.
    Attachment 304568
    Here it is put together.
    Attachment 304570
    Attachment 304572
    Here are all the pieces of the Zombie Sign ready to be put together.
    Attachment 305590
    Here are photos of the finished Zombie Sign.
    Attachment 305596
    Attachment 305598
    Attachment 305600
    One adjustment we made was adding color to the routed out Dibond letters with red sticker vinyl.
    Below is the Zombie Sign with out the colored letters, we felt the red vinyl makes the the sign stand out more compared to leaving it black.
    Also, we left the letter "O" black to give it contrast to the other letters, being the center point of the Zombie Sign.
    All the parts of this sign was CNC routed & engraved on the Vision 2550 CNC Router, well everything except the red sticker vinyl lol.
    Attachment 305602
    Dec 2016
    5
    Interesting idea and great implementation!
    That's totally one of the coolest signs I've seen! Nice job!
    Alex~
  1. need zombie hammer dxf plz!!
    By zippotter in forum MetalWork Discussion
    Last Post: 05-14-2014, 09:27 PM
  2. Replies: 2
    Last Post: 03-12-2013, 04:23 PM
  3. Configuring steps/unit.....what unit?
    By HereinCS in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2011, 02:57 AM
  4. FANUC 15-MA Battery unit & I/O unit etc
    By gbowne1 in forum Fanuc
    Last Post: 05-05-2010, 02:47 AM
  5. Zombie PCs spew out 80% of spam
    By WallCrawler in forum Community Club House
    Last Post: 06-08-2004, 02:06 PM
