586,075 active members*
4,143 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Shopmaster Mill Turn mill tram
Results 1 to 8 of 8
    Jan 2016
    11
    Any suggestions for tramming the mill? I emailed Shopmaster and I have not receive a reply. It would be nice if a parts breakdown was available, which might help.
    I received their demo/tester. I've only been cutting air, learning the implementation of G01 linear interpolation, etc. Seems to be a nice, good value machine, other then the mill tram being off. I did have to replace the caster wheels with heavier duty wheels
    Dec 2007
    77
    Re: Shopmaster Mill Turn mill tram
    I don't recognize your name- did you buy it used from someone? Can you tell us the serial #.
    Jan 2016
    11
    Hi JT
    S# MS0150015
    Thank you.
    Walt
    Dec 2007
    77
    Walter, I checked your e-mails, and the last one we received was in June when your machine was delivered. Send me another e-mail today to test if it comes through and I will respond and attach the instructions for tramming the head.
    Jan 2016
    11
    I have been able to correspond with Shopmaster regarding this. My memory's vague, but I think correspondences did not work through the Shopmaster website but did through direct Email so they were good with trying to respond.
    BTW, I think shimming the bottom of the three (front or back) columns for the "Y" tram adjustment is better then shimming the mill head spindle itself.
    Jun 2015
    85
    Quote Originally Posted by JTJT View Post
    I've sent you similar questions and gotten either no response or only a partial response.
    Why can't you just post the instructions? maybe add a support or documentation section to your website.
    Jan 2016
    11
    As I already mentioned, I did receive instructions for tramming by shimming the mill head spindle housing. I thought it more solid to shim the bottom 3 corresponding columns and noticed that shims were already there, so I reshimmed (I got the demo/tester. I also had to replace the caster wheels (original probably 250 lb.(x4) load capacity for 1000+ lb machine, perhaps screw jacks were not in place for testing, and went bad within time (probably fine for quick moving, just use the screw jacks when done moving) I bought the wheels (used orig casters) from Welcome : Stanley E. Smith Online Store. I think part number is WPHXKK3.112XXXR8S (packing slip breaks down to WMP03-221(wheel), BR:1.2-1.38(bearing roller) and SP:1.2-1687 (spanner). I had to spread the caster forks a hair, but works well.
    One problem, I've had, was that the Z movement (mill) sounded like it was crashing, during middle of travel (intermittently). Tightening the set screws for the Z stepper motor shaft pulley seems to correct this.
    Mar 2016
    8
    Is this true on everything with shopmaster. Is everything big secret?
  1. Shopmaster 2014 and older tram
    By uberlinuxgeek in forum Shopmaster/Shoptask
    Last Post: 03-26-2016, 07:28 AM
  2. New 2015 Shopmaster Mill-Turn
    By Fiero Addiction in forum Shopmaster/Shoptask
    Last Post: 02-01-2016, 05:39 AM
  3. Mill Turn / Turn Mill / Multi Task C Y B Programming
    By aldepoalo in forum BobCad-Cam
    Last Post: 04-22-2015, 09:31 PM
  4. Mill Turn / Turn Mill / Multi Task C Y B Programming
    Last Post: 04-22-2015, 09:24 PM
