586,075 active members*
4,075 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Roctech CNC Routers > Chinese ATC Water Cooling Spindle with BT30 Tool Holder
Results 1 to 8 of 8
    Aug 2014
    74
    Spindle with BT30 Tool Holder, which can be used for graphite engraving.
    Oct 2010
    1189
    Re: Chinese ATC Water Cooling Spindle with BT30 Tool Holder
    Which kW is reached and which capabilities like Encoder to spindle and vfd Thx Thomas
    Gesendet von iPhone mit Tapatalk
    Aug 2014
    74
    Hi Thomas,
    The spindle is 5.5kw with 12000rpm. If you use encoder on this spindle, VFD-C inverter is needed?
    Are you going to use this spindle? To work on what kind of material?
    Catherine
    Oct 2010
    1189
    question is it possible to have an encoder at spindle yes no and do you offer an vfd for it yes no and if yes may i have a link at the specs like 220 v how to control the speed and is there also an 2,2 kw version ? is it suiteable for steel ? speaking which kinds of bearing are in that thing 12 k sounds more like suiteable for wood and plastic
    Gesendet von iPad mit Tapatalk
    Aug 2014
    74
    Hi Thomas,
    Encoderok,
    VFD-C,ok,
    Speed change, ok,
    220V, ok
    bearing,NSK
    2.2kw, ok
    Could you tell us that you need ATC spindle or not?
    What kind of machine will you use this spindle on? How is the intensity of the machine?
    Waht kinf of work will you do on the steel? Tapping? Engraving?
    For better communication, my skype is cnc06.roctech
    Oct 2010
    1189
    Hi cathy,
    Which tool head do you have at the atc ? We use on our machines ISO 30 and that is why we need encoder to supper tool orientation.
    If customer want ATC they of course need tapping. I have seen on your page that you do routers and i have nit seen the Spindle
    So do you buy it from another vendor or duo you do it yourself.
    And the reason i ask is we do Vertical mills for steel and for the act version an ISO30 spindle is needed parallel i think of doing an router where an fast spindle may make sense as well
    thomas
    Aug 2014
    74
    Hi Thomas,
    We make cnc routers and buy spindle from other suppliers.
    Most spindles on our machines are HSD air cooling spindle.
    For this water cooling spindle, made in China,it is BT30 tool holder, different from ISO30.
    Will you make a router by yourself?
    Oct 2010
    1189
    Hi ,
    in short yes we have vertical mills for steel which use ISO30 so the idea is to share tool pool
    thx thomas
  1. help a n00b make a BT30 tool holder on lathe?
    By acannell in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2013, 07:30 PM
  2. BT30 tool holder DXF
    By Master_CNC in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2007, 03:03 PM
