586,075 active members*
3,832 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > matsuura mv 500 (1981) tool changer help
    Dec 2015
    8
    Hello and thanks in advance. I recently bought a matsuura mv 500 with a 16 tool tool changer on a carousel. when I put air to the machine the tool changer moves forward and down. when I go and manually actuate the switches for carousel forward and back I need to hit reset for it to back and forward, the switch to actuate it up and down will not pull it all the way up. all this time the atc light is green no matter where the carousel is but the machine wont move unless I un hook the air and push it to its limit tool changer home position then the machine will hand wheel and start spindle. has anyone had a similar problem or any idea where to start. this tool changer was working before the move. the air supply is at 80psi as recommended by matsuura. the solenoids have been cleaned.
    any ideas?
    thanks,
    Patrick
    Nov 2020
    Re: matsuura mv 500 (1981) tool changer help
    sir, we have also same problem,
    but when we tried on manualy operation it works everything,
    when we comand for tool T2M06 the magzine movment starts but the alarm light on imedietly,
    any on help about pmc parameter of this machien.
  1. Replies: 0
    Last Post: 01-08-2016, 05:21 PM
  2. Matsuura MC-500V Tool Changer Problem
    By nlh in forum Uncategorised MetalWorking Machines
    Last Post: 09-02-2015, 05:50 AM
  3. Auto tool changer Drum type tool magazine.
    By maylin1105 in forum News Announcements
    Last Post: 02-18-2012, 09:44 AM
