586,075 active members*
3,803 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Water cooled against air cooling
    May 2006
    20
    Question Water cooled against air cooling
    Hi All, just wondering if a water cooled spindle can be run with out water and if so how long ??
    Thanks ...stevep
    Apr 2013
    1899
    Re: Water cooled against air cooling
    Quote Originally Posted by STEPHENPRESCOTT View Post
    Thanks ...stevep
    I would DEFINITELY not run a water cooled spindle without water. A water cooled spindle has no fan, so if you run it there will be no cooling at all. It is a closed motor and would pretty fast become too hot. How long it will take to generate smoke... who knows... depends on the motor... but will definitely be fried pretty fast, that's my guess.
    Thread title is wrong. This is not about air cooling vs. water cooling, it is about water cooling or no cooling.
    Jun 2004
    6618
    It would not take long to have a melt down. Think of a car engine or outboard motor. Those don't work very well once water is taken away.
    Lee
    Generally, I would say that any more than a few seconds would be catastrophic.
    However.
    If you search for the thread here on the Big Bamboo machine, you'll see a water cooled spindle running with no water. The spindle is inside the dust collection hose, and is cooled by the airflow from the dust collector. I believe he's been running it for several years like that.
    Personally, if you don't want to use water, buy an air cooled spindle. Your chance of it lasting are a LOT better.
    May 2006
    20
    However.
    Thanks for all of your Info guys.......now I know
    Stevep
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Air Cooled vs Water Cooled Pros and Cons and Advice
    By Tundraman in forum Spindles / VFD
    Last Post: 06-20-2015, 08:41 PM
  3. Replies: 0
    Last Post: 04-27-2014, 03:49 AM
  4. Water cooling or air cooled spindle
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 12-25-2012, 01:48 AM
  5. Air cooling a water cooled spindle
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 08-24-2011, 01:12 PM
