586,647 active members*
2,028 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Engraved Zero's and O's are tilting and are out of round.
Page 2 of 4 1234
Results 21 to 40 of 70
  1. #21
    Jun 2012
    59
    Re: Engraved Zero's and O's are tilting and are out of round.
    Thanks, I have watched just about every video there is on the subject. I'm sure I can do it. Getting the right sized balls (and the right number) is my main concern. How are they measured?
  2. #22
    Jun 2004
    6618
    A micrometer is the best way, but when measuring old ones, do it a few times around the ball turning the ball slightly each time.
    They can get football shaped.
    Lee
  3. #23
    Jun 2012
    59
    I'm getting .0925 - .093 I'll probably need to convert that to mm?
  4. #24
    Jul 2004
    1424
    Quote Originally Posted by RickPflimlin View Post
    Probably would not be noticable 1 " high but my business doesn't call for 1" serial numbers. As covered in earlier post Vectric VCarve Pro 6.5 and V8 from different computers. Three years without any problems.
    I was asking because if it was noticeable in larger letters than it wouldn't be a hardware problem, but a software problem. But since you are generating posts from different software versions, I guess you have already ruled that out.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  5. #25
    Jun 2012
    59
    Good point. I had ruled it out but from a different viewpoint. Thanks for the confirmation.
  6. #26
    Aug 2009
    986
    Spring loaded diamond drag bit. The letters are 1/10 of an inch high.
    I didn't know that you were drag engraving. I'll bet you a large amount of money that your engraver has worn to the point that it's got some sideways movement.
    Put an indicator on the engraver and see how much side play it has.
    Frederic
  7. #27
    Jun 2004
    6618
    That is whay I suggested that he try it with a V bit or something. To rule that out. It would not have to be much deflection to get that kind of error on such a small engraving. The fact that some letters appear straighter may very well indicate a worn spot in the barrel of thee drag bit.
    Lee
  8. #28
    Jun 2004
    6618
    You should be able to get precisely what you need in either MM or inches.
    Lee
  9. #29
    Jun 2012
    59
    Quote Originally Posted by TXFred View Post
    Frederic
    Save your money. That was my first thought, but I have three engravers from two sources. My favorite one has a lot of hours the others not many at all. The results is exactly the same with all three.
  10. #30
    Jun 2012
    59
    Quote Originally Posted by LeeWay View Post
    .093 is 2.38mm. I can find 2mm and 2.5mm balls but nothing in between? Could these be 2.5mm balls worn down? They seem too consistent for that???
  11. #31
    Jun 2012
    59
    That is why I suggested that he try it with a V bit or something. To rule that out. It would not have to be much deflection to get that kind of error on such a small engraving. The fact that some letters appear straighter may very well indicate a worn spot in the barrel of thee drag bit.
    Before I tried my other two engravers I ordered three more. Two will be here today and I will double check with them but I'm sure I have eliminated that possibility. Spindle wear is another matter, how can I check that?
  12. #32
    Dec 2008
    740
    How are you holding your stock?
    Step
  13. #33
    Feb 2006
    1072
    I'd suggest as another test, engraving an uppercase T and L. The T will be single, along-axis strokes and the L will be a single along-axes stroke but with a 90-degree turn during the movement. That should isolate axis movement vs. flex/runout/backlash. Is it possible that you have accidentally turned on Formula Axis Correction in Mach3? If you have ever used it in the past, the equation you used will still be present.
    Randy
  14. #34
    Jun 2012
    59
    Quote Originally Posted by TurboStep View Post
    Step
    Very tightly in a vise.
  15. #35
    Jun 2012
    59
    Quote Originally Posted by zephyr9900 View Post
    Randy
    I have never used it and I wouldn't know how to turn it on or off. We all bump keys at the wrong time so anything is possible. How would I check?
    I'll try the T & L test but it will probably be tomorrow. I'm way behind in getting some computer generated samples worked up for customers.
  16. #36
    Jun 2012
    59
    I should restate that I have found that I have .007 - .008 backlash in my X axis.
    After the adjusting the gibs and the thrust bearings I'm thinking it has to be down to the ballscrew. Even with less than 3000 hours on it. I had to replace the Z ballscrew at about 2000 hours. That was a little more obvious with little chrome bits in my way oil.
    Spindle slop is also a possibility but I can't feel any.
  17. #37
    Jun 2012
    59
    Finding the right sized balls to replace the ones in the ballscrews is now my biggest problem.
  18. #38
    Jun 2006
    3063
    That seems like a lot more than should be expected. A while back I traced a few thou of lost motion in the X-axis of my 1100 to a loose ball nut carrier on the X axis. The lost motion largely disappeared when the SHCS in the mounting block were tightened.
    Attachment 307548
  19. #39
    Jun 2004
    6618
    Here is another ball source, though I haven't ordered from them.
    They can get you very close to 2.38 mm chrome steel balls. They also have .093" size. Those look like they are 10 cents each. Part number 37432.
    Bal-tec
    $20.00 minimum order.
    Lee
  20. #40
    Jun 2012
    59
    Quote Originally Posted by MichaelHenry View Post
    Attachment 307548
    I read about someone else having that problem and wished I had checked when I had all the guards and covers off.
    I will check that out but I will have a replacement on hand before I tear it down that far again. Maybe I can fish a long extension in there and check them?
Page 2 of 4 1234
  1. tilting an IH mill
    By cyclestart in forum Benchtop Machines
    Last Post: 04-20-2014, 02:47 PM
  2. Experience with Tilting 4th Axis?
    By GJeff in forum Tormach Personal CNC Mill
    Last Post: 03-09-2013, 01:24 AM
  3. Replies: 5
    Last Post: 04-16-2012, 09:25 AM
  4. Left tilting or Right Tilting Table Saw Blade?
    By diarmaid in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 02-27-2009, 03:57 PM
  5. Tilting Spindle for X1?
    By heycorey in forum Benchtop Machines
    Last Post: 02-22-2009, 02:44 AM
