587,056 active members*
3,479 visitors online*
Results 1 to 11 of 11
    Feb 2016
    10
    Post Fanuc O-T missing parameters
    We have a Daewoo PUMA 6-s serial #0593 with Fanuc O-T the machine has been shut down for 3-4 years and when we tried to hook it back up it turns out that the power and mainboard was fried. We have changed mainboard, power, I/O, memory and axis cards and successfully booted up again
    We are now facing to add all parameters to get the machine up and running and by that we need some help
    our specs:
    All Fanuc parts:
    Mainboard: A02B-0098-B511
    Mainboard power: A16B-1212-0950
    Graphic: A16B-2201-0350/07A
    Memory: A16B-2201-0101/07A
    I/O: A16B-1211-0970/01A
    Axis: A16B-2200-0391
    X axis Motor: A06B-0128-B177
    z axis motor: A06B-0143-B077
    Power supply A06B-6087-H115
    Spindle amp: A06B-6088-H215
    Servo amp: A06B-6+079-H208
    Any input to get us back up running in terms of parameters would be greatly apriciated, sorry for any bad English
    Regards RTS Norway
    Dec 2012
    395
    Re: Fanuc O-T missing parameters
    Hello RTS,
    Put your post in the Metal Working Machines - Daewoo/Doosan forum, [ dhardt ] is the person that can help you.
    Regards,
    Heavy_Metal
    Feb 2016
    10
    Hi and ty for the reply, we have posted in the Daewoo section also so far with no luck or reply. Is there really no one with the parameters out there?
    Jun 2006
    475
    Can Daewoo/Doosan help you?
    Chich.
    Dec 2012
    395
    Hi RTS,
    Here are parameter of a Puma-8s-Fanuc-otc, maybe similar to your machine.
    Need parameters for Puma 8s/Fanuc OTC
    Regards,
    Heavy_Metal.
    Feb 2016
    10
    Hi, we tried the Norwegian supplier but no luck since they claim this machine is too old and they did not save any parameter settings for them, they could try to contact manufacturer but it could take weeks before they got reply for this type
    Feb 2016
    10
    Quote Originally Posted by Heavy_Metal View Post
    Hi RTS,
    Regards,
    Heavy_Metal.
    Hi, we have tried those with no luck, it seems there are some changes between the 6-S and the 8-S, our main concern is that they use different servo/motor parameters and by that it does not communicate with the I/O and axis card from the mainboard, ty for the reply
    Dec 2012
    395
    Hi RTs,
    Check - Metal Working Machines - Daewoo/Doosan forum again.
    dhardt posted a parameter list for the 6-serie 0T.
    Regards,
    Heavy_Metal.
    Feb 2013
    788
    posted here, as well.
    Attached Thumbnails Attached Thumbnails P6 0T parameters.pdf
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Dec 2015
    12
    Dear all
    can you please help for DAEWOO 4-3S parameters
    i will be thankfull we lost it
    Dec 2015
    12
    Unhappy Re: Fanuc O-T missing parameters
    [QUOTE=SOJI;2188898
    Dear all
    can you please help for FANUC OT-A DAEWOO 4-3S parameters
    i will be thankfull we lost it[/QUOTE]
    THANKS ADVANCE
  1. Replies: 9
    Last Post: 04-20-2018, 11:50 AM
  2. Missing Parameters?
    By ghyman in forum Okuma
    Last Post: 09-27-2013, 09:38 AM
  3. Missing Parameters!!
    By karan.engg in forum Machinery Manuals / Brochures
    Last Post: 12-14-2012, 09:44 AM
  4. Parameters missing
    By karan.engg in forum Fanuc
    Last Post: 11-28-2012, 04:51 PM
  5. Replies: 4
    Last Post: 03-10-2006, 07:37 PM
