586,058 active members*
4,344 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Pimp my lathe. Converting a HF 44142 3in1 to 3 phase
Results 1 to 14 of 14
    Dec 2010
    153
    Decide to upgrade my 3 in 1 again. This time converting from single phase 3/4hp single speed to 3 phase 1hp variable speed via a VFD.
    Video of the test run of my dumpster motor + VFD:
    https://youtu.be/kS9FsNZOQi8
    My upgrade BOM:
    https://docs.google.com/spreadsheets...it?usp=sharing
    and some early photos attached.
    Aug 2015
    14
    Re: Pimp my lathe. Converting a HF 44142 3in1 to 3 phase
    Check out these Leeson Motors.
    Leesondirect.com
    Dec 2010
    153
    Seems overpriced. Automation direct has similar motors for ~$50 less. More than likely will just try and find another used motor and rebuild it myself again. Save quite a bit that way and my hobby milling will never tax it too hard.
    Dec 2010
    153
    Feeling motivated tonight here is another video.
    https://youtu.be/fEy6GD6PAZ0
    Got all the remote IO wired up to test switches and ran the controller though it's paces. Also set up the acceleration select input so I can have different ramp down speeds depending if the motor was turned off via the normal control (fwd/off/rev switch) or by one of the EPO switches.
    Nov 2009
    4415
    My understanding is that voltage controls rpm and current controls torque.
    A lazy man does it twice.
    Jan 2007
    94
    No. VFD means "variable frequency drive". Frequency controls speed.
    VDFs are Awsome, and 3-phase motors can be had on eBay for cheap - even new ones. I've converted my lathe, mill, and even my 4x6 bandsaw. VFDing a cheap bandsaw was a bit silly but I had the parts already, and now the motor stays cool on long cuts, and I can crank up the speed for aluminum.
    Nov 2009
    4415
    I understand what a VFD does to some degree. I also have 1 on my lathe. I am responding to his current going down as his rpms increased.
    Dec 2010
    153
    Quote Originally Posted by Fastest1 View Post
    The voltage/frequency curve is flat from 60 to 120Hz in my current setup. Would think for a given speed increase the work needed to spin the motor would go up with speed. (bearing / air drag) If that is correct since my voltage is fixed the current should go up (I*V = P). One thing that it could be is at the increased speed the fans are cavitating and moving less air therefor dropping the total load on the motor....
    Dec 2010
    153
    Part 3 playing with inductive proximity sensors as a pickup for the spindle RPM meter.
    https://youtu.be/RHz4de7N4dY
    Dec 2010
    153
    Some minor progress today got most of the wire strung in the house and the service disconnect output all buttoned up. Just 1 more hole, 1 board, 3 wire staples, and 7 screws till I am done
    Dec 2010
    153
    Another update video here:
    https://www.youtube.com/watch?v=jRLHzYihbGM
    Got another junk motor (out of a snowbank no less) and rebuilt it with acceptable results. Has a slight whine at high speeds I am not crazy about but for $20 worth the risk.
    Dec 2010
    153
    Semi final wiring diagram done and attached. Just placed the order for the parts I was missing. New Lathe motor mount and motor installed now.
    Attached Thumbnails Attached Thumbnails 3phase_HF_upgrade.pdf
    Dec 2010
    153
    Some minor updates to the wiring diagram had to run one main contractor off a switch on the other. If I tried to close both at the same time my transformer would brown out and they would chatter and not close. By running the second off the switch on the first it introduces just enough delay to prevent the chattering and they close first time every time.
    Dec 2010
    153
    Part 5:
    https://youtu.be/H5DQSUnfKGg
    project is not only still alive it has been done for a while. Just finally getting around to editing the video.
    More to come.
  1. converting single phase to 3 phase
    By spm in forum Phase Converters
    Last Post: 07-08-2013, 01:45 AM
  2. Converting 1 phase Machine to 3 phase
    By richred in forum Phase Converters
    Last Post: 04-21-2012, 10:06 PM
  3. Craftex B2229 3in1 Mill-Lathe-Drill Heat issues.
    By trunner in forum Uncategorised MetalWorking Machines
    Last Post: 01-07-2011, 09:35 AM
  4. Convert HF RE: 44142 3in1 lathe or sell and buy a G0602 ??
    By David Bord in forum Benchtop Machines
    Last Post: 02-04-2010, 12:19 PM
  5. Converting a Roto-Phase for use with a CNC....
    By gearsoup in forum Phase Converters
    Last Post: 05-19-2007, 04:58 PM
