603,371 active members*
4,532 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Look ahead on OSP-P200
Results 1 to 7 of 7
    Feb 2016
    Does anybody know how to disable/enable look ahead on OSP-P200?
    Dec 2008
    3211
    Re: Look ahead on OSP-P200
    Use single block
    - look ahead cannot be bypassed when using cutter comp, as this is required to calculate compensated tool move positions relative to the programmed contour ( minimum look ahead is 4 lines of NC code )
    Feb 2016
    Thanks. I am not using cutter comp. I need to do some calculation using variables (VC) and in auto mode (not single block) the calculation is done ahead of time. Immediately after I start the program the values of variables change to their final state..
    Jun 2008
    372
    Try this
    VOPRB[2]=VOPRB[2] OR 128 (Sets NC Opt Para Bit No2. Bit7 to 1)
    Code in here
    VOPRB[2]=VOPRB[2] EOR 128 (Set NC Opt Para Bit No2. Bit7 to 0)
    Apr 2009
    1273
    I think you can add 4 dummy blocks or use an M331 if I remember right. Don't have a book in front of me at the moment...depends on if it's a L or M though.
    Best regards,
    Feb 2016
    Great. It works. Thanks
    Jun 2015
    4189
    hy bffelix, i know that this is 4yrs old, but what exactly where you after ? why did you needed to buff-prohibit some math ?
    please, can you share your code ? kindly
  1. P200 Apps
    By tea hole in forum Okuma
    Last Post: 02-28-2018, 07:37 AM
  2. Part-off on P200-LA
    By Tancuda in forum Okuma
    Last Post: 01-10-2016, 03:17 AM
  3. Osp p200 controller
    By jamessiffel in forum Okuma
    Last Post: 01-23-2013, 07:31 PM
  4. OSP p200 screen
    By hoosierdaddyno1 in forum Okuma
    Last Post: 04-26-2011, 11:20 PM
  5. P200 Thinc Api Integration
    By cncwapner in forum Okuma
    Last Post: 12-30-2009, 08:12 PM
