586,042 active members*
3,796 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Charmilles Robofil 400 Generator Chain failure Diagnostics listed.
    Jun 2009
    11
    The machine started slowing down and using more wire than normal and faulted on us a couple times with this message.
    E02 P01?
    So I loaded the Auto-Diagnostic software into the machine and the CNC control passed everything but the Generator Chain failed. Charmilles recently discontinued support for this machine and it’s been such a solid machine I don’t have any other service contacts for Charmilles.
    Diagnostic Summary:
    Attachment 309404
    Error Details:
    Attachment 309402
    Attachment 309400
    Attachment 309406
    Generator Boards are:
    852449 UPH1-2
    852447 UP1-4 should be OK }
    852447 UP1-4 should be OK } I have a spare and when cycling the three boards through every spot the errors never change.
    Auto-Diagnostic Version: G-16
    System Software: MK3.1B 1/24/97
    Any help is appreciated,
    John
    Jun 2009
    11
    Re: Charmilles Robofil 400 Generator Chain failure Diagnostics listed.
    If anyone remembers the code to enter the service menu under Monitor that would be a plus.
    Jan 2006
    104
    hi
    E02 P01? is a 24 vdc failure usually.......
    i can repair UP/UPH boards if you can t-shoot it down to that
    mac
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Sep 2012
    15
    Quote Originally Posted by mdynac View Post
    hi
    mac
    I am based in India. I have a Robofil 200 and having the same problem. After loading the Communication disk the screen goes blank with this message E02 P01 ? at the bottom. Is this related to 24volts output. Have you found the solution to this problem. If so please pass on the details.
    Thanking You
    Yogesh.
  1. charmilles robofil 290
    By zekry10 in forum EDM Discussion General Topics
    Last Post: 02-24-2016, 02:25 AM
  2. DNC CHARMILLES ROBOFIL 310
    By tecnomaqq in forum EDM Discussion General Topics
    Last Post: 01-17-2014, 04:34 AM
  3. Charmilles Robofil 300 Generator Parameters for rough and skim????
    By johnston.jer in forum EDM Discussion General Topics
    Last Post: 06-11-2013, 02:35 PM
  4. charmilles Robofil 190 or charmilles Robofil 290
    By Fontez in forum Post Processors for MC
    Last Post: 03-12-2013, 04:48 PM
