603,383 active members*
3,711 visitors online*
Results 1 to 7 of 7
    Mar 2016
    X y axis inverted.
    Hi, I'm a noob to the cnc world, but not to the cad and design world. My problem is that my MACH3 software is reading my x & y axis wrong, at least in the sense that I'm used to. And I for the life of me cannot get them to flip. I'm using aspire and AutoCAD as my design mediums. But when I input the toolpath into MACH3 it wants to run the x axis in the y direction and the y in the x. I've reconfigured my ports and pins so that they read and move, somewhat, in the correct direction, EXCEPT that when I have the machine zeroed at the lower left corner, it reads the x in a negative number and the y in a positive. Being since almost everything I design will be using the up and right directions add positive movements, this is causing me quite a bit of frustration. I certainly hope this makes sense. Thank you in advance.
    Jun 2014
    777
    Re: X y axis inverted.
    Sounds like you have reversed the x direction in your ports and pins to get it going in the right direction instead of just swapping the wires of one coil of your x motor around.
    Mar 2016
    Quote Originally Posted by Jon.N.CNC View Post
    Thank you for your response Jon. I did not physically switch any wires on the breakout board, I simply swapped the pins in tbdMACH3 program itself. Which has the machine going in the direction I want it to, EXCEPT tbd x axis still starts at zero and goes to the right as negative. Do I need to physically change the wiring?
    Apr 2004
    5948
    No, you can change it in the software. Either go to Config/Homing Limits and change the "X" where it says "reversed" or go into Config/Ports and Pins/Motor Outputs and change the direction bit. Don't do both things, or you'll be back where you started...
    Andrew Werby
    Website
    Mar 2016
    25
    If you are confident your wiring has not changed, I would generate a small program with a spot drill located at XYZ 0 then check precisely where the tool goes.
    Next generate a 2nd spot location at X+ (whatever value you can reach), then a 3rd at Y+. If the machine goes where it is supposed to go in +, then your toolpath(s) you previously generated where set from a different origin.
    To correct the origin it might just be a G command to enter in your post-processor.
    Are you using the right one for your controller?
    Jun 2014
    777
    Awerby hit the nail on the head, I'm a bit ocd and have to have the settings as default so I would switch the motor wires At the driver. which wires did you swap at the Bob?
    Mar 2016
    Quote Originally Posted by awerby View Post
    Thank you! Between you and Ron, I got it figured out. That was EXACTLY the problem. Thank ALL of you for answering! I'm sure I'll have more need of your combined expertise! On fact I DO have another question, but I'll start a new thread. Thanks again
  1. X axis inverted, mastercam output needed
    By jolulank in forum Post Processors for MC
    Last Post: 05-13-2017, 08:22 AM
  2. Anilam 3000 - inverted Y axis
    By Darron Black in forum CNC Machine Related Electronics
    Last Post: 05-17-2014, 04:11 PM
  3. Anilam 3000 - inverted Y axis
    By Darron Black in forum Controller & Computer Solutions
    Last Post: 05-17-2014, 01:13 AM
  4. Mori Yasnac LX1 X axis inverted
    By misiunike in forum Mori Seiki lathes
    Last Post: 01-21-2013, 09:26 PM
  5. inverted y axis
    By Jack000 in forum Coding
    Last Post: 04-30-2010, 06:36 PM
