586,108 active members*
3,196 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Using my upgraded DIY CNC and DIY pen holder (video)
    Apr 2013
    1899
    This is a CNC test video, I am using my DIY pen holder to draw a pattern and write. The pen holder is just another DIY project, it took me about an hour to make it, including the figuring out of "how to make it" and from which readily available material.
    My DIY CNC is upgraded. The mechanical parts are replaced, I made a new X, Y and Z axis. The upgraded CNC has 16mm supported round rails and 1605 ball screws and ball nuts. The speed is increased by 3 times, maximum speed is now 1500 mm/min, using the same NEMA23 steppers and 24V driving voltage.
    Next in turn for upgrade is the electrical parts, new power supply and control box will be made. I have all the parts and will start as soon as I fixed a dust extractor as well. After that the spindle will be changed as well, probably a water cooled brush less VFD motor will be the one.
    For details, please visit different related posts on my blog:
    Adapting Camera
    Or if you just want to make a similar pen holder you can visit that post, it contains a lot of detailed images.
    Adapting Camera: Making a pen holder for my CNC
    https://youtu.be/ItUOqsYaRB4
    May 2005
    3920
    Re: Using my upgraded DIY CNC and DIY pen holder (video)
    Nice. Looks like a simple but stable solution for holding a pen.
    By the way looks like you made significant upgrades to your machine, it has the look of quality craftsmanship.
    Apr 2013
    1899
    Thank you. Yes, the pen holder actually works better than expected, even though the hole for the tip is a bit larger than necessary, due to a last (too late) change in the design. I originally drilled for a Parker pen refill, but changed my mind and decided to use a less exclusive, plastic fantastic copy. The tip of the copy is slightly smaller.
    I am very happy with my upgrade, it really is a huge change, going from the slow, rattling/vibrating version 1 to a stable, fast and clear sounding version 2 is really nice. Anyway, the upgrading continues, next in line is the power supply and after that is the control box change/upgrade. I have all the parts ready, and the design is ongoing mostly in my head.
  1. Replies: 10
    Last Post: 11-06-2012, 11:43 PM
  2. Can 5T be Upgraded to 6T?
    By shaftalignment in forum Fanuc
    Last Post: 06-27-2012, 02:21 PM
  3. Die alignment: To dowel the punch holder or the die holder first?
    By PhoenixMetal in forum Diemaking / Diecutting
    Last Post: 09-11-2010, 02:11 AM
  4. Rotary Broaching Tool Holder Set-Up Video
    By peter@slater in forum News Announcements
    Last Post: 10-07-2008, 06:18 PM
  5. Well I upgraded to XP pro
    By WallCrawler in forum Computers / Desktops / Networking
    Last Post: 02-23-2004, 10:54 PM
