603,316 active members*
2,768 visitors online*
Page 1 of 6 123
Results 1 to 20 of 107
    Jun 2007
    27
    PCB Autoleveler Plugin for UCCNC
    Hello All,
    I have written a plugin for UCCNC.
    it is for auto leveling PCB milling.
    Are there people who want it and test it?
    I want to know if there are any bugs....
    there are 3 files.
    first is M331.txt copy it in C:\UCCNC\Profiles\Macro_Default
    second is the AutoLevelerCA.dll copy this in C:\UCCNC\Plugins
    third is a sample pcb gcode file...
    sorry for bad english..
    thanks..
    Attached Files Attached Files
    Sep 2005
    287
    Re: PCB Autoleveler Plugin for UCCNC
    Cahit,
    thanks for submitting that. Unfortunately I don't have a PCB milling machine yet, I make my PCBs with a transparency and the UV light method. Then I do the hole drilling on my cnc plasma table LOL.
    I'm curious though, what exactly is auto levelling PCB milling ??
    Keith.
    Jun 2007
    27
    Beefy,
    here some videos, better than 1000 words.
    i don't know how to explain
    https://www.youtube.com/watch?v=xHSwWntbOPk
    https://www.youtube.com/watch?v=aQOz7nS2AgQ
    Cahit
    Apr 2006
    3498
    do you have the same for Mach3. excellent work by the way
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Jun 2007
    27
    Khalid,
    not yet, but in the future i will write a .exe for mach3
    thanks..
    Sep 2005
    287
    Quote Originally Posted by cahit View Post
    Beefy,
    Cahit
    Thanks Cahit,
    I think I understand what it does, it simply gets the exact surface positions of a range of points across the whole board surface then applies any necessary offsets at those "points" (maybe within a square area around each point, +/-X and +/- Y from each point) ??????
    I like that because I've always wondered how you can accurately mill such a small depth on a "flexible" board. You would be completely relying on the board laying perfectly flat with the milling machine table.
    Good stuff.
    Apr 2006
    3498
    cahit, thanks for your hardwork i will be anxiously waiting. I don't want to resurface the spoil board of my 4ft x 4ft machine. If you make a program in following way it will be quite helpful for all of us:
    1- I will place small metallic plates of equal thickness at different locations ( Grid points) of my complete working area.
    2- I will get all the locations data using proximity probe.
    3- This will be reference data and i will use the same to calibrate the Gcode for the work.
    Is it possible?
    Jun 2007
    27
    Quote Originally Posted by Khalid View Post
    Is it possible?
    I think that's possible, whynot. but I'm not a profesional programmer or cnc machine user. I do it in my spare time just for fun. Therefore I can not promise of when I can program it ...
    and also my english is bad
    oh i have another idea for you. in stead of step 1 can't you use something like this?
    Apr 2006
    3498
    Wow... wow.. you are a genious man That is a great idea... Now i am just waiting for the program/plugin for Mach3.
    Apr 2009
    7
    Thank you for the plugin!
    I've tried to mill boards with it -
    фрезеровка плат, подготовка и настройка станка перед работой (pcb milling, board auto leveling) - YouTube
    Several suggestions -
    1. add pause between end of probing and start milling, to let me remove probing tool and prepare for actual milling.
    2. allow to enter values in fileds by keyboard
    3 remove limit (30mm maximum spacing between probe points)
    4 remember last entered settings!
    5 add probe sensor height (I've added it to M331.txt file for me)
    6. remove first G31 probing (or make it optional)
    But anyway it works, big thanks for your plugin!
    Jun 2007
    27
    Hi all,
    here update and improved version v1.0013 of the autoleveler. for those who want to test or use it.
    download it here: https://www.dropbox.com/sh/433w6dh6e...MawhJOPKa?dl=0
    or below
    it works great with Coppercam. Gcode ISO standard... working on compability of different Gcode's genereted by different post processors...
    regards
    Jun 2007
    27
    I need any kind of sample G Code Files. I will greatly appreciate if you can mail me to [email protected]
    i want to test the plugin
    regards
    cahit
    Jun 2007
    27
    hi,
    another version of autoleveler. now support for G02 and G03.
    regards
    cahit
    Jul 2016
    HI Cahit,
    Thank you for this plugin.
    I tried it but only work for your example.
    Doesn't work for my G-code files i.e. when I load the files in UCCNC , it doesn't get loaded in the Autoleveer. However it does with your example.
    Do you have any idea why?
    Best regards,
    rab
    Jun 2007
    27
    HI Rab,
    it can be the path name of the file. if it is long then gives an error. try to make the filename short.. you can see if there are 3 dots (...) in the filename on the diagnostics tab, if so than it does not work.
    that will be fixed in the next releases of uccnc.
    regards.
    Cahit
    Jun 2007
    27
    hey rab
    if it does not succeed, can you mail me some examples to [email protected]
    i will check it
    Cahit
    Jul 2016
    Hi Cahit
    Thank you for the reply.
    I played with the path and I changed the file name to short one. I called the file PCB1. I even swapped your example files content with mine but still doesn't work.
    I will email you the g-code file that you can try it yourself.
    Jun 2007
    27
    hi all,
    thanks to rabrabengineer, solved a big bug..
    so latest version is v1.0019
    it works well with UCCNC v1.2021
    regards
    Jul 2016
    Smile Re: PCB Autoleveler Plugin for UCCNC
    hi all,thanks to rabrabengineer, solved a big bug..so latest version is v1.0019regards
    Great work Cahit,Millions thanks
    Jul 2016
    Thanks for the video Ivan ! Big machine! Will check the autoleveler Macro this weekend :-)
    Thanks for your suggestions about the improvements.
    Also of course thanks a lot for the great plugin to cahit. I have a similar one as a feature installed in ESTLCAM using an Arduino but if it works fine I will use yours in future.
    Hartmut
Page 1 of 6 123
  1. UCcnc CAM
    By vmax549 in forum UCCNC Control Software
    Last Post: 09-16-2016, 04:19 PM
  2. FED UP with UCCNC
    By jcarpenter2 in forum UCCNC Control Software
    Last Post: 03-10-2016, 11:24 PM
  3. UCCNC & UC300
    By camivic in forum UCCNC Control Software
    Last Post: 10-27-2015, 08:45 PM
  4. UCCNC Wizards (;-)
    Last Post: 09-20-2015, 02:35 AM
  5. Has anyone really used UCCNC?
    By greggv in forum UCCNC Control Software
    Last Post: 08-16-2015, 10:45 AM
