586,195 active members*
4,075 visitors online*
IndustryArena Forum > MetalWorking Machines > Sharp CNC > SV2412S Tool Carousel is Posessed
    Sep 2015
    We have a Sharp SV2412S with almost no hours on it. As soon as you flip the breaker on the back of the machine the tool carousel starts turning and doesn't stop. Doesn't matter if the controller is off and both e-stops are engaged, it keeps rotating until you shut power off to the machine. There aren't any chips up in the carousel where the magnetic sensor is. What could be the cause of this?
    Nov 2014
    34
    Re: SV2412S Tool Carousel is Posessed
    check wire that connects optical switch
    Apr 2014
    6
    I personally just started using a Sharp machine. Honestly the biggest issue i have had is with the tool carousel. Sometimes when i go to do a tool change in MDI it brings up the wrong tool location and crashes 2 holders into each other.
    Maybe a re-occurring issue with these machines. Has happened twice to me. Certainly not an operator error.
  1. Tool carousel pot
    By bigbobr in forum Fanuc
    Last Post: 01-29-2016, 10:48 AM
  2. tool carousel locked up
    By TXMILLGUY in forum Fadal
    Last Post: 01-04-2012, 07:09 AM
  3. Biesse tool carousel
    By Nathan.fisher in forum CNC Tooling
    Last Post: 03-11-2011, 07:32 AM
  4. Tool Carousel Operation
    By rbcmetalwork in forum Sharp CNC
    Last Post: 12-30-2010, 09:16 PM
  5. tool carousel alignment
    By rubino2112 in forum DNC Problems and Solutions
    Last Post: 12-27-2006, 07:26 PM
