603,311 active members*
3,481 visitors online*
    Mar 2006
    20
    Spindle enable alarm Fanuc OTB
    Hi any body
    My machine is Tongil control Fanuc OTB alrm 998 Rom parity , I set old parameter X & Z axis run Jog & Zero oke but can't run spindle , can't set Diagnostic , If you can please help me
    Oct 2006
    586
    "just asking" but what about a door interlock
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Nov 2004
    53
    If you have a model a ) control (without a graphics board) the memory board contains 5 chips 2 of those are the Eprom's for the ladder and 2 of them are the proms for the firmware and the remaining one is for the servo.
    There should be a code on the screen (hex value) indicating where in the prom's the error is coming from.
    Having just gone thru this with a customer last week what I did was order the 3 rom's and a new memory board to make sure the problem was solved.
    You need to make sure you have a complete back-up of parameters and part programs.
    Check to make sure all the chips are properly seated in the sockets, there are a total of 5 in sockets.
    I doubt clearing the memory will help you at all. If the control wont boot at all normally and you dont have a backup or a hard copy from the mtb you should be prepared for a challange.
    Good Luck
    Mar 2006
    20
    Thank you
