587,221 active members*
3,129 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > Pierce RUR 2500 Burny 10 lcd Lincoln Invertec PC100
Results 1 to 6 of 6
    May 2014
    4
    Hello, I am having issues getting this Plasma cutting machine up and running.
    Upon powering up the system I get an error message as show in attached picture
    Also the lower control panel doesn't power up (to the left of the emergency stop button in attached picture) Is this causing the error message?
    Any help/advise you could provide is very much appreciated!
    Mar 2016
    59
    Re: Pierce RUR 2500 Burny 10 lcd Lincoln Invertec PC100
    Wow, Did you purchase the machine new or second hand?
    Looks like a software error to start with. My initial suggestion would be to contact Burny support. Lincoln owns Burny now and I suspect they have decent telephone tech support. Next - what do your schematics say about power to the lower panel? Could be just a loose connection/blown/missing fuse or it may not be enabled until the control boots up completely.
    Lastly, if you have decent computer/electrical/electronic skills then have at it yourself, however, if you don't, you may want to get a professional involved
    May 2014
    4
    Quote Originally Posted by bytor View Post
    Hi Bytor thanks for reply,
    The machine was purchased new quite some time ago. I contacted Lincoln and they advised that it could be the cmos battery on the Mother Board as the time on the XP software was incorrect and the licensing wasn't working. So I replaced that and set the time and BINGO it booted up properly. Still though the lower control panel isn't powered but now it displays this error message: Ill look into this... I am thinking its the front emergency stop button...
    Mar 2016
    59
    Might be an interesting place to start. Does this have one of those Pilz e-stop relays in the electronics cabinet?
    May 2014
    4
    Not sure what that is? With another call it turned out to be a blown fuse in the electrical cabinet underneath the control unit. Not sure why it is blowing however? This machine has seen barely any use... Fuse F2 keeps blowing which apparently feeds the drive motors/cards. Has anyone experience this issue that could advise a potential solution? The machine when first turned on did travel for a sec with the jog controls but then it just stopped.
    May 2014
    4
    Just to feedback, I fixed the issue. The drive carriage was slightly out of alignment. So we squared this up and changed the fuse to the correct slow burn fuse and Bingo, all working now.
    Jack
  1. Replies: 0
    Last Post: 11-20-2013, 08:34 AM
  2. Lincoln pro-cut 55 HF ???
    By DJR in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-04-2012, 05:04 AM
  3. Emco PC120 lathe and PC100 Mill help required
    By j.c.freeman in forum EMCO CNC Machines
    Last Post: 08-31-2010, 10:05 AM
  4. any experience with plasma "PIERCE RUR 2500"??
    By tibet in forum CNC Machining Centers
    Last Post: 03-29-2008, 09:48 AM
