586,036 active members*
3,521 visitors online*
    Sep 2014
    66
    vacuum boxes and hold downs
    Hi.
    I am expecting a 6090 machine soon ..I'm very new at cnc
    i have seen a number of u tube videos on making vacuum hpls downs.
    The donek tools guy uses a shop vac.
    I'm toying with the idea of building a table since double stick tape can let go when least timely and clamps and screws can be a pain.
    I expect to be doing guitar parts and similarly sized jobs in timber.
    I would appreciate advice re vacuum boxes eg is a shop vac gutsy enough? how big a chamber is necessaty etc etc
    and other advice re hold downs generally.
    I have done a few searches and didn't get much joy there.
    Rob.
    Aug 2009
    655
    Re: vacuum boxes and hold downs
    Not sure how big guitar parts are bit sounds like you need a high vacuum gasket jig set up (if small).
    A few threads cover the theory but long and short is small pieces are hard as they have a small area for the vacuum (really the column of air above) to push on.
    And trust me they can fail at bad times too (is there ever a good time I ask rhetorically).
    Look at all Star adhesives for gasket bits. Never used but I do peruse.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    So can vacuum, or any other methods.
    Look at the vacuum clamping at joewoodworker.com
    That's similar to what you want. High vacuum with fixtures, not an entire table. And no, a Shopvac won't work for this.
  1. Clamps and Hold-downs
    By MrTallant in forum EDM Discussion General Topics
    Last Post: 08-21-2014, 08:06 PM
  2. Hold-downs
    By IQChallenged in forum News Announcements
    Last Post: 01-23-2010, 02:25 AM
  3. New T Hold downs installed
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2008, 07:57 PM
  4. Vacuum hold-downs and rotational problem about the z axis
    By cpcp in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-08-2006, 02:02 PM
  5. Wet hold downs
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 12-18-2004, 07:20 AM
