586,115 active members*
3,504 visitors online*
    Jan 2016
    53
    Help needed to set new home position
    I guess I'm mixed up here. I'm moving my laser head to a position that I want to set as my new 0,0,0 reference point.
    So I jog (using G1 X Y code) to the position I want and then issue G92 X0 Y0 Z0
    Then I jog away in the X and Y axis and issue a G28 command. The laser head positions to another location and I thought it would (or should) go to the position I set with G92 X0 Y0 Z0.
    I guess I don't understand this.
    Thanks for any help...
    Feb 2006
    1792
    Re: Help needed to set new home position
    G28 sends the tool to the reference position which is fixed on a machine.
    Dec 2008
    3109
    Quote Originally Posted by sinha_nsit View Post
    To add...
    Your machine has a "base" co-ordinate system\, which cannot be accidently adjusted... assume that it is the permanently fixed machine home position
    - you use the G92 code to set a "User" co-ord system relative to your stock placement.........it is linked to the machine co-ord system ( in the background )
    G28 always refers to the machine coordinate system,
    so a G28 G0 X0Y0 will move to the home position of the machine
    & a G0 X0Y0 will move to where you made the G92 part origin
    Jan 2016
    13
    Look up G30 in your book. The machines I work on use this as a 2nd reference point return position. They are set in the parameters of the control.
    Regards
    Jan 2016
    53
    Thanks everyone...!!!
  1. set position home
    By Fledge2b in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-15-2016, 05:10 PM
  2. Home position
    By bisongear in forum Okuma
    Last Post: 10-02-2012, 08:55 PM
  3. Home Position of CNC
    By Ashish B in forum CNC Machining Centers
    Last Post: 07-11-2010, 08:46 AM
  4. Replies: 4
    Last Post: 10-28-2009, 06:39 AM
  5. Home Position
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 03-26-2008, 04:30 PM
