586,383 active members*
3,864 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Arduino CNC Shield GRBL unwanted stepper movement
    Aug 2015
    Good day
    I have bought a arduino cnc shield and loaded GRBL on the arduino , i have confugred grbl using G code sender . i am having an issue where by when i move the X axis the Y axis makes a small movment (small jerking movement ). However when i move the Y axis the X axis remains still(works properly).I also noticed that its only occures when initiate movment on the X axis once the axis is in motion there is no movement on the Y, the movement is small but after a few initiation of X axis movement this throws off my Y axiz position. I have changed the driver , seprated the motor wires form each other. changed microstep settings and i have seen no change in behaviour. Any idea what might be wrong ?
    Dec 2014
    640
    Re: Arduino CNC Shield GRBL unwanted stepper movment
    Humm...I have the same setup basically...Arduino Uno-gShield. Never had that issue at all. You might get on the Shapeoko2 forum and ask there. Those folks have extensive experience with that setup.
    The Shapeoko Forum ? Index page
    Quote Originally Posted by GRoopan View Post
    Good day
    Aug 2015
    Quote Originally Posted by fretman_2 View Post
    I have been looking around the net for similer problems so far no luck hopefully i will find the problem or some one might have a idea .
    Mar 2017
    Re: Arduino CNC Shield GRBL unwanted stepper movement
    I had the same issue with steppers doing the chatter movement just like yours. I had figured out I was getting interference from the power supply powering up my LED lights mounted to the gantry to light up the work area.I moved the LED power wires away from the stepper wires and now I have no more stepper chatter.
    Jul 2016
    660
    it`s a power supply noise, try using a PC power supply on your arduino
  1. Replies: 1
    Last Post: 08-19-2016, 11:57 AM
  2. Arduino Uno + CNC Shield + Nema 17 Stepper + Universal GCode Sender
    By Arduino_Uno_Dyl in forum Open Source Controller Boards
    Last Post: 03-02-2016, 04:11 PM
  3. Poor output from Arduino CNC Shield v3
    By mike0866 in forum Arduino
    Last Post: 10-13-2015, 06:46 AM
  4. 3020T Arduino + GRBL + CNC Shield V3 Conversion
    By metropolicity in forum Chinese Machines
    Last Post: 09-07-2015, 02:42 AM
  5. Motor/Stepper/Servo Shield for Arduino
    By steamboatmodel in forum Open Source Controller Boards
    Last Post: 11-18-2013, 07:36 PM
