603,855 active members*
3,720 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Mazak Integrex 100Y Subspindle Milling Mode not working
    Jan 2007
    I'm having trouble milling on subspindle on Mazak Integrex 100Y.
    I'm probably missing some G and M codes ,or these that I use are misplaced.
    I'm using Gibbs 8.0,and the post is not perfect for this machine.
    Milling on Main Spindle works OK.
    Below I'm posting tape code for milling operation on Main Spindle (working fine),and Subspindle (not working).
    When I simulate tool path it works,but running prog,alarms out,
    with message about B axis not locked.
    Please take a look at my code ,and tell me what's wrong
    Milling Mode Code Presentation on Main Spindle (working)
    ( OPERATION 7, HOLES )
    ( RGH_TURN_MAIN_SP )
    ( TOOL ID 6, 1. DIA. CENTER DRILL )
    ( #1 CARBIDE CENTER DRILL #002.152 )
    ( CS#9 - GATE1 )
    ( MAIN SPINDLE )
    N134T0606.8B12
    N135G53P1
    N136M302
    N137M200
    N138G50W0.
    N139G110C1
    N140G0C0.
    N141G97S2500M203
    N142M250
    N143B15.
    N144M251
    N145G125X2.694Y0.Z-3.467R1
    N146G17
    N147G0G98X0.Z5.66C0.M8M153
    N148Y0.
    N149Z2.5
    N150G83X0.Y0.C0.Z-.5R0.F20.M210
    N151C-120.
    N152C-240.
    N153G80G0Z2.5
    N154Z5.66
    N155G69.5
    N156G30P1V0.
    N157G30P1U0.
    N158G30P1W0.
    N159M9M154
    N160M205
    N161M1
    Milling Mode Code Presentation on Sub Spindle (NOT working)
    ( OPERATION 22, HOLES )
    ( MAIN SPINDLE )
    ( CS#6 - XY PLANE )
    ( SUB SPINDLE )
    N412T0606.15B18
    N413G53P1
    N414M300
    N415M200
    N416G50W#605
    N417G110C2
    N418G0C0.
    N419G97S2240M203
    N420M250
    N421B180.
    N422M251
    N423G17
    N424G0G98Z-2.5M8M153
    N425G112M19S0
    N426X0.
    N427Y0.
    N428G83X0.Y0.Z2.R0.F360.M210
    N429G80G0Z-2.5
    N430G30P1V0.
    N431G30P1U0.
    N432G30P1W0.
    N433G28W0.
    N434M9M154
    N435M205
    N436M1
    Dec 2004
    11
    Here's a spot drill cycle from an Integrex drilling on the main, side and sub. There are some G and M code differences, you might give these a try and see if it helps
    (1/2 SPOT DRILL)
    N14 T22022.0 B72
    G53 (T32 COORD SYS)
    G17 (XY PLANE)
    M201 (MILL MODE)
    G111
    M212 (C-AXIS UNCLAMP)
    G28 H0
    G0 C0
    M211 (C-AXIS BRAKE)
    M302 (MAIN SPINDLE)
    G0 G90 G98 G97 S3820 M203
    M8
    X2.638 Z1. C0
    G83 X2.638 C0 Z-0.063 R0.9 F25.
    G80
    G0 X20. Z5. C0
    M1
    (1/2 SPOT DRILL)
    N15 T22022.1
    G111
    G0 C0
    M211 (C-AXIS BRAKE)
    G19 G0 G90 G98 G97 S3820 M203
    M8
    X4.912 Y0 Z-1.308
    G87 X2.528 Y0 C0 Z-1.308 R0.9 F25.
    G80
    G0 X4.912
    G30 Y0 M9
    G30 U0
    G30 W0 M205
    M1
    (1/2 SPOT DRILL)
    N16 T22022.11
    G53 (T32 COORD SYS)
    G17 (XY PLANE)
    M300 (SUB SPINDLE)
    G112 M201 (MILL MODE)
    G110 C2
    G112 M212 (C-AXIS UNCLAMP)
    (G50 C#500)
    G0 C0
    G112 M211 (C-AXIS BRAKE)
    G0 G90 G98 G97
    G112 S3820 M203
    G50W-#501
    M8
    X2.124 Z-2.766 C0
    C0
    C0
    G83 X2.124 C0 Z-1.686 R0.9 F25.
    G80
    G30 Y0 M9
    G30 U0
    G30 W0 M205
    M1
    Jan 2007
    Thanks!
    We are going to try it
    mzbik
    Jan 2007
    Thanks!
    We are going to try it.
    Mzbik
