586,117 active members*
3,510 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > What year is this Kit My center 1 Fanuc 0M
Results 1 to 9 of 9
    Aug 2013
    89
    I am looking at this machine and need an estimated manufacturing date ?
    Serial # 02198
ID:	318844Click image for larger version.
    Feb 2009
    6028
    Re: What year is this Kit My center 1 Fanuc 0M
    Hard to say without more info on the control, probably 91-94 vintage.
    Sent from my A3-A20FHD using Tapatalk
    Aug 2013
    89
    I was hoping someone might have one like it or know from the control panel ? I will be picking it up tomorrow so I should find out some more info.on it. I purchased it in an auction site unseen and I won ? Hopefully its a good one.
    The auction was an asset liquidation and I don't really think they knew much about the stuff the were auctioning ? They did not go into any detail about any of the equipment as to the condition if it was running or not.
    If anyone has any info.or manuals and such they can share I would be very grateful
    Aug 2013
    89
    It is an October 89 machine got all manuals and parameters with it. Its been in storage for a while so I am sure the battery has died. How hard is it to input the parameters back in and where can I find info.for that ?
    Aug 2013
    89
    Finally got the twins home not in the shop yet one is still on the trailer and the other is on the ground. I've built a skid for them bolt it to the base and I can skid it into the shop to get them set up and running again.
    I will post more as progress moves forward.
    Attachment 319712Click image for larger version.
ID:	319714Click image for larger version.
    Aug 2013
    89
    Went to the auction to buy one machine but came home with two consecutive serial numbers. - - - 95, - - - 96 the 96 looks to be in better shape has new screws as well. plan to get them both up and running again.
    Both are October 89 Fanuc 0M-B control AC servos and digital. Not sure on the spindle speed I think they are the 1300 K spindles.
    Feb 2009
    6028
    Parameter input is just time consuming. Probably 8k spindles, high rpm spindles were not super common in 89. Most builders were in that 6-8k range back then.
    Aug 2013
    89
    Need HELP have powered up my machine and have Alarm code 531 have tried the instructions in the manual and have not been able to get it fixed. Its says to enter G23 How can I enter G23 to fix the problem ?
    Jan 2009
    52
    Did you get them running. How is it going?
  1. Victor V center-4 Fanuc 10M Help!
    By vladimir1409 in forum Fanuc
    Last Post: 02-10-2016, 12:27 PM
  2. Replies: 0
    Last Post: 02-18-2015, 11:49 AM
  3. Replies: 0
    Last Post: 01-07-2015, 09:48 PM
  4. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
  5. Replies: 0
    Last Post: 08-10-2013, 02:31 PM
