586,104 active members*
3,331 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > NEED HELP! New Pwr supply connection Leetro 6515 to RECI power supply
    May 2016
    Had power supply go bad. Running 80w RECI tube. Ordered a new chinese power supply...thought it was a RECI brand as advertised but seems to be working fine...just cannot figure the pin-out. According to the diagram on the pwr supply it as follows...
    5v - TH - TL - WP - G - IN (1-6 respectively).
    From the Leetro 6515 board the wires are Yellow/Green - Ground, Blue = Analog, Brown = Laser on/off
    I can get raster to work great in the following pin-out....
    Brown on #3/TL
    Blue on #4/WP
    Yellow/Green on #5/Ground
    I can only get vector cutting to work on this pin out...
    Blue on #2/TH
    Brown on #4/WP
    There is a 4th red wire I cannot figure out where it goes.
    About to drive me to drinking. Really need machine back up in production asap. Any suggestions very greatly appreciated! Thanks - Gary
    Nov 2007
    71
    Re: NEED HELP! New Pwr supply connection Leetro 6515 to RECI power supply
    long over due. reply.. that red wire is 5v wire. have you sorted your issue?
    5v = red wire
    others are...:
    TH =laser output high
    TL laser output low
    WP =water protection. if no water protection switch in use jumper to ground.
    I = input.
    G= ground.
    I do not know whats what on your machine wiring wise.. Chinese folk do strange things that make no sense to white folk... but this is a start.
  1. Blown power supply dy10 for reci laser 80w
    By shreifali in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 05-30-2017, 04:49 AM
  2. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  3. Stepper Motor Driver MA860H power supply connection
    By airtruk in forum DIY CNC Router Table Machines
    Last Post: 10-24-2013, 03:06 AM
  4. Reci Power Supply
    By Ephesian Art in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-06-2012, 02:13 AM
  5. 5 volt power supply connection
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 05-10-2008, 09:07 PM
