586,102 active members*
2,485 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Need Help Cincinnati saber 1000 Fanuc control
    May 2009
    16
    Hi All
    Im hoping someone can help me when I try to home my machine it does the initial homing sequence on all three axis but when it has to do the final home on the Y axis it starts to move in a + direction I then get a 1002 fault ( axis alignment time ) and 1030 axis alignment abort .
    Please any help would be appreciated
    Warren
    Nov 2011
    14
    Re: Need Help Cincinnati saber 1000 Fanuc control
    Hello Warren
    Just posted a similar post as this, thought I would offer something. I have a Sabre 500 with Heidenhain control (Fanuc drives), mine does all the alignment and then stops, no error.
    From how mine homes/aligns, it is the last bit of movement just before the tool alignment you are having trouble with, for this, I would check and clean the proximity switches at the back, could be the it is not switched and times out.
    Not knowing if the setup time can be extended.
    Under normal circumstances and all aligns, does yours then swing the carousel under the spindle to align tool drum ?
    If it does swing the tool drum under the spindle, does the carousel move before to present tool No.1?
    Many thanks
    Ian
    Mar 2008
    285
    Warren,
    If you are in the UK contact:
    MAG Maintenance UK Limited (formerly Cincinnati Machine Limited)
    Unit 6, Maybrook Road, Maybrook Business Park, Minworth,
    Birmingham
    B76 1AL
    England
    tel +44 121 313-5308
    www.mag-ias.com
    They will want your machine Serial Number (70xx-F0x-xxxxxx) and Control wiring diagram number (09120xxxx)
  1. Replies: 1
    Last Post: 01-31-2016, 08:53 PM
  2. Problems with a Saber 1000
    By 17asleep in forum Cincinnati CNC
    Last Post: 08-17-2013, 05:16 PM
  3. Saber 1000 loosing tram
    By Brian Pugh in forum Cincinnati CNC
    Last Post: 12-10-2012, 05:58 PM
  4. Cincinnati VC10-1000 with Acramatic 900 Control
    By gilchapa in forum Cincinnati CNC
    Last Post: 06-04-2012, 05:48 AM
  5. Cincinnati Saber 750
    By clip in forum Cincinnati CNC
    Last Post: 12-03-2008, 05:32 AM
